    Dismiss Notice
What is an AVR?
Discussion in 'AVR' started by ElectroMaster, Aug 25, 2009.
  1. ElectroMaster
    ElectroMaster Administrator
    Jul 5, 2002
    2,057
    127
    Broadbeach, AU
    Overview
    An AVR is a microcontroller which was developed by Atmel, and uses a Modified Harvard architecture 8-bit RISC single chip. The AVR was one of the first microcontroller families to use flash memory located on-chip for program storage, as opposed to One-Time Programmable ROM, EPROM, or EEPROM used by other microcontrollers at the time.
    And for your reference, AVR is not an acronym and does not stand for anything in particular.
    Basic Families
    AVRs are generally classified into four broad groups:
    • tinyAVR — the ATtiny series
      • 1–8 kB program memory
      • 6–32-pin package
      • Limited peripheral set
    • megaAVR — the ATmega series
      • 4–256 kB program memory
      • 28–100-pin package
      • Extended instruction set (Multiply instructions and instructions for handling larger program memories)
      • Extensive peripheral set
    • XMEGA — the ATxmega series
      • 16–384 kB program memory
      • 44–64–100-pin package (A4, A3, A1)
      • Extended performance features, such as DMA, "Event System", and cryptography support.
      • Extensive peripheral set with DACs
    • Application specific AVR
      • megaAVRs with special features not found on the other members of the AVR family, such as LCD controller, USB controller, advanced PWM, CAN etc.
    • Atmel At94k FPSLIC (Field Programmable System Level Integrated Circuit)
      • An AVR core on-die with an FPGA. The FPSLIC uses SRAM for the AVR program code, unlike all other AVRs. Partly due to the relative speed difference between SRAM and flash, the AVR core in the FPSLIC can run at up to 50MHz.
    External Links
    Where to Buy
    • Like Like x 1
  2. microtexan
    microtexan New Member
    Mar 28, 2008
    352
    6
    Texas
    Man, you've been busy with some new ideas. Good show old man.
    Thanks.
  3. ElectroMaster
    Jul 5, 2002
    2,057
    127
    Broadbeach, AU
    Thanks microtexan! Lets hope it all helps ;)
    Also, if anyone has any input or wants to add to what I have in the first post then please let me know..
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. johankrava
    johankrava New Member
    Oct 14, 2008
    14
    0
    Didn't know about the Atmel At94k FPSLIC.
    Thanks!
  6. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,294
    647
    Derbyshire, UK
    ONLINE
    As I understand it the early AVR's were EEPROM, and ATMEL called them 'FLASH' solely for advertising purposes, it was much later when they started using actual FLASH memory. MicroChip followed suite, and started calling their EEPROM based chips FLASH as well.
  7. rahulshah
    rahulshah New Member
    Dec 18, 2008
    53
    0
    Vadodara, India
    AVR probably stands for Alf-Vegard-Research or Alf-Vegard-Risc microcontroller.
  8. saidmsbah
    saidmsbah New Member
    Sep 8, 2010
    5
    0
    thank youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
  9. 3v0
    3v0 Coop Build Coordinator Forum Supporter
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    I was thinking the first AVR was developed in Finland and rights purchased by Atmel.
  10. srikanthsamaga
    srikanthsamaga New Member
    May 25, 2008
    97
    3
    I have seen some video about AVR history, some 2 students developed it as an academic project.
  11. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Yes two students from Norway rather then Finland. The origin or AVR was pointed out to me my an ETO member from Norway.
    Wikipedia say
  12. thecritic
    thecritic Member
    Nov 23, 2009
    242
    0
    Kathmandu, Nepal
    What about programmers for them?
  13. wkrug
    wkrug Active Member
    May 30, 2010
    280
    29
    Germany
    There are different ways to program an AVR Controller.
    1. ISP: There are a lot of In System Programable Adapter for AVR Controllers in the Internet. Give that for search item in an search engine an you'll find it.
    This Programmers are most cheap and can program an AVR Controller in the target board.
    The Controller must have an internal or external clock source to work with this mode.
    The used ports ( Reset, MISO, MOSI, SCK most ) never shoud be connected to active output Ports of periphal Chips. The minimum load at this Ports must be higher then 4700 Ohms.
    At some Controllers e.g. ATMEGA128 are used other Ports for SPI - Look into the Datasheet to look for.
    I think that is the most used variant to program an AVR at home.
    2. Parallel High Voltage Programming: That goes with special Programmers. The Controller must been demountet from the target board and putted in into the programmer. All AVR Controllers i know, support this Method.
    STK 500 Board supports this Method e.g.
    3. JTAG: It is possible to programm such an Controller by the JTAG Interface.
    The Jtag interface pins should been taken to a Connector at the target board.
    Normally this Interface ist used to debug the Software of an Controller, while an running application. But the AVR can also be programmed with this Interface too. Some Ports are exclusive used for the Jtag Interface an can't be used for other things!
    This Method works only on the bigger AVR >ATMEGA8.
    4. Bootloader: In this Method an Bootloader will be programmed onto the AVR, by one of the Methodes 1...3.
    Then an according program on PC will be started.
    That program activates the Boot loader software at the Controller and loads down the application program into it.
    Because the Bootloader is only software, all of thinkable comunication ways between AVR and PC are possible. It appends from the Bootloader Software and the according download program.
    • Like Like x 1
Share This Page
