    Dismiss Notice
Weird delay problem.
Discussion in 'Arduino' started by RMIM, Nov 29, 2013.
  1. RMIM
    RMIM Member
    Jul 17, 2006
    154
    0
    (London) Epsom Surrey. England.
    Dear All,
    I’m new to arduinno and c – there’s this problem that's driving me nuts, I hope someone can shed some light on it.
    I was building a sky remote/tv/projector that I could control on my phone using Bluetooth and a program called microcontrol(android app). It seems to work great – I then wanted to leave the prototype world and make the real thing. I bought the same atmel chip as my arduino and made a permanent circuit. Again it seem to work great except for the fact it would eat batteries.
    So I wanted to use power down mode.
    I felt my system would feel smoother and not laggy if I had a delay so it would remain in loop for say 15sec before going on to sleep.
    My method to keep it in loop before going to sleepNow() was to
    count=count-1;
    if (count==0){sleepNow(); count=150;}
    but for some reason it does not delay unless I leave the line Serial.print(" LLLL start of loop LLLL "); - which is weird as it really has nothing to do with anything, it was just added so I could see where it was in the program when it was running.
    As soon as I remove this line the delay does not work and it goes quickly to sleep. If I include the line it delays as it should – I can even increase count and it will delay for longer as expected.
    What’s going on? (thinking about it seems when Serial.print(" LLLL start of loop LLLL "); is not running causes it to jump out. what's causing the jump? the interrupt? why is running something on serial.print stopping it?)
    Thanks.
    Code (text):
    * IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
    * An IR LED must be connected to Arduino PWM pin 3.
    * Version 0.1 July, 2009
    * Copyright 2009 Ken Shirriff
    * http://arcfn.com
    #include <IRremote.h>
    #include <SoftwareSerial.h>  //software serial as hardware serial not working!
    #include <avr/interrupt.h>
    #include <avr/power.h>
    #include <avr/sleep.h>
    SoftwareSerial mySerial(2, 10); // RX, TX change to pin 2 from 9 for interrupt
    IRsend irsend;
    const int ledPin =  13;
    unsigned long count = 150;
    //////////////////////////start setup/////////////////////////////////
    void setup()
                                      Serial.begin(9600);
                                      mySerial.begin(9600);
                                      Serial.print(" QQQQ void setup QQQQ ");
                                      pinMode(2,INPUT_PULLUP);
                                      pinMode(13,OUTPUT);
    ///////////////////////////end setup ////////////////////////////////
    /////////////////////////start loop//////////////////////////////////
    void loop()
                              digitalWrite(13,HIGH);
                              Serial.print(" LLLL start of loop LLLL ");// WHEN I REMOVE THIS LINE MY DELAY DOES NOT WORK
                          if (mySerial.available())
        char serr = mySerial.read();
        if(serr == 'P')    {goto jump6;}
        else if(serr == 'Q')  { goto jump7;}
    goto start;
    jump6:
                irsend.sendNEC(0xAF548B7, 32); // vol up
                Serial.print(" vol up");
                delay (50);
                goto start;
    jump7:
                irsend.sendNEC(0xAF5A857, 32); // vol down
                Serial.print(" vol down");
                delay (50);
                goto start;
    start:
    count=count-1;
    if (count==0){sleepNow(); count=150;} //loops 150times then jumps to sleepnow for delay
    ////////////////////////////////////end loop////////////
    ///////////////////start sleep///////////////////////////
    void sleepNow(void)
    Serial.print("xxxx in sleep xxxx ");
    delay(100);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Choose our preferred sleep mode:
    sleep_enable(); // Set sleep enable (SE) bit:
    attachInterrupt(0, pinInterrupt, LOW);  //interrupt 0 is on pin 2
    digitalWrite(13,LOW);
    sleep_mode(); // Put the device to sleep:
    sleep_disable(); // Upon waking up, sketch continues from this point.
    //////////////////////end sleep///////////////////////////////////
    /////////////////////stop interrupt////////////////////////////////
    void pinInterrupt(void)
      detachInterrupt(0);
      Serial.print("--- TURN OFF INTERR ---");
  2. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    Difficult to say because the Arduino sketch documentation is so bad. Maybe the call to serial functions enables/disables global interrupts or does something else that affects the system.
  3. RMIM
    RMIM Member
    Jul 17, 2006
    154
    0
    Thanks for the reply misterT.
    I had a thought last night of adding noInterrupts(); at the start of the loop, then Interrupts() to the SleepNow. - could that work?
    edit - just tried it - did not help.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. RMIM
    RMIM Member
    Jul 17, 2006
    154
    0
    I have stripped all the code out and left just the sleep and delay bits in. What should happen when pin 2 goes low it should keep the led on until count = 0 and then sleep.
    For some reason even this is jumping out! How do I make a simple delay? Why is this method not working? Why did it work when the serialprint line was in?
    Code (text):
    unsigned long count = 350;
    void setup()
      pinMode(13,OUTPUT);
    void loop()
    count=count-1;
    if (count==0){sleepNow(); count=350;}
    void sleepNow(void)
    sleep_disable();
      detachInterrupt(0);
    edit: adding the lines Serial.begin(9600); and Serial.print("hello"); in the appropriate places makes everything work. why?
  6. RMIM
    RMIM Member
    Jul 17, 2006
    154
    0
    ok the penny has dropped. in order to see a sizable delay count had to be 350,000 - when Serial.print was present obviously that contains many lines of assembly (which are hidden from us) so only needed count to be 350. that's my guess.
  7. april
    april Member
    Mar 12, 2012
    250
    20
    Cairns Great Barrier Reef -QLD-Australia
    You do realise that delay(1000); is a 1 second delay
    350 is 350 milliseconds and 350,000 is 350 seconds?
    The loop would execute very fast 20 MHz
    Use Serial,println() to make screen readable
    how about
    delay(2000); in the loop or something
    Also
    for (int count=350;count<0;count--) should save work
    Edit::Typo() --I can see spending my time looking was a waste of time . I'll not bother again.
  8. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,887
    500
    Cleveland, OH, USA
    I don't understand that math. Isn't delay() a delay in milliseconds? (http://arduino.cc/en/Reference/delay)
    Happy New Year.
    John
  9. RMIM
    RMIM Member
    Jul 17, 2006
    154
    0
Share This Page
