    Dismiss Notice
Wall Power adapter output concern
Discussion in 'General Electronics Chat' started by Uziel, Sep 17, 2017.
Tags:
  1. Uziel
    Uziel New Member
    Mar 17, 2017
    3
    0
    Hello, this question may sound senseless but I am novice, just looking for clarification. My Cordless phone has a Wall wart AC Power Adapter rated at 9v 500mAh. As far as replacement is concerned, does output power only matters or we have to be specific with ratings also? Like a 4.5V 1A adapter output will also be 4.5W as original rating. I have read in this forum that higher current rating may not matter but higher voltage may damage. Also, I have heard that SMPS based supplies senses the actual load and outputs accordingly. Please correct me.
  2. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    You need to get a 9V adapter.
    You need a 500mA or larger. (I would look for 500mA to 1A) In theory a million Amps will work just fine. (if you can afford one LOL)
    Amps or Watts need to be equal to or larger.
    • Like Like x 1
  3. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,044
    541
    AZ 86334
    Local thrift shops have dozens of these older-style, iron core transformer wall-warts for ~$1. Do not use a modern (light-weight) switching power supply, but look for the ones that have a bit of weight when you pick them up.
    It is usually much harder to match the coaxial plug that was on the old charger than to match the voltage/amperage rating.
    Make sure that the replacement wall-wart has AC (unrectified) output; not DC (internally half or full-wave rectified)
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,251
    1,218
    Cardiff, Wales
    :confused: First check markings on your existing adapter and your phone base unit to be certain whether the unit requires an AC input (which I doubt) or a DC input. Make a note, too, of the plug polarity if the unit input is DC.
  6. MikeMl
    Mar 17, 2009
    11,044
    541
    AZ 86334
    About one third of older consumer appliances utilized an AC wall-wart where the rectification, battery charging, and regulation is done inside the appliance; not the wall-wart. The wall-wart markings clearly show if it is AC or DC output.
    Most older DC wall-warts have either one internal rectifier (half-wave), or an internal full-wave bridge, and some have an internal filter capacitor and some dont. When used as a DC supply for projects, the DC wall-warts are usually have a big voltage drop-off between no-load and loaded, and require a chip voltage regulator inside the project. If they dont have an internal filter capacitor, or the internal one is too small, you usually have to add one externally...
Share This Page
