()blivion
Active Member
()blivion submitted a new article:
Voltage Splitter. - A lot of times when building circuits, (such as op-amp circuits), you'll find that you need a power
Read more about this article...
A lot of times when building circuits, (such as op-amp circuits), you'll find that you need a power supply with both positive(+) and negative(-) rails, in addition to a common ground(gnd). It is easy enough to connect two batteries or two wall adapters together and use the center connection for your ground, but there are some problems with this. What if one battery goes dead faster than the other? What if you can't have or don't want two wall adapters hanging off the wall? What if you can't...
