Voltage Comparator with negative signal inputs
hery
hi every one,
i wanna make PWM signals by comparing the triangular negative signal and negative sine wave signal as its inputs.
i use LM311 as comparator. i have simulated in proteus, but its doesn't work well.
here i attach the circuit
On your Sim you show that pin7, Col out is used as the signal out.
You should have pin1 Emitter out connected to -Vcc, 0V on your circuit.
thank you eric,
i have try, but the signal inputs are reduced,
maybe it should use double supply so that the LM311 can compare negative signal inputs,,
Try these LM311 connections:- pin1 to 0V (Gnd) and pin 4 to the -12V rail.
