voice scrambler or encryption
Hi, I'd like to make a telephone voice scrambler but don't what are the resources that can help ( ICs..etc) , I 've a good knowledge in microcontroller programming.
I've googled and I've found that chip PC4440T , but can't find any helpfull examples.. also I'd like to have a full duplex communication ..
What are your suggestions ?
There are plenty of ideas, applications and theories out there. Do you want to deter the casual listener or hide communication from rouge government spies with quantum super computers? If you specify the level of security you're after we might be able to help you. To obscure your conversations from nosy neighbors simple speech inversion can be used (Voice inversion - Wikipedia, the free encyclopedia). If you want to go a little more secure use your microcontroller experience to capture audio from an analog to digital converter, employ the proper encryption algorithm and give one to the other party.
Yea I wanna high security that's why I'm going to use the microcontroller like dsPIC ..etc
but I wanna a full duplex communication how can this be applied through telephones ??
My problem is I don't know how to interface a microcontroller's ADC with the landing line telephone then Digitize that voice --> Encrypt it ... Then at the other telephone it should ADC then decrypt , but this is half duplex communication .. right ??
Thanks for your reply.
If you really want to do this right, I'll point you to the right direction...
https://www.electro-tech-online.com/custompdfs/2010/04/B12.pdf
Hi all
I would like to inquire the best implementation technique for designing of a microcontroller based voice scrambler
A one time key for rolling code encryption is most secure.
The key is not transmitted using the same channel.
The digital voice must be encoded from raw data before the Trellis encoder depending on generation of RF output and in reverse for decoding.
This is a complex design beyond your scope.
I suggest you use this.
I want the simplest model and design possible, what I know is I can use frequency and time domain to scramble my input voice signal.The microcontroller will make it secure but how can I design the circuit for security and confidentiality purposes?.
The newbie necro post gets us again. :rolleyes:
