    Dismiss Notice
Virtual UART in windows (C#)
Discussion in 'Microcontrollers' started by misterT, Sep 29, 2017.
  1. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    I have a sensor. It works fine and sends data through uart. I also have an application to log all kinds of data in a particular format.
    The data format from the sensor is not compliant with the data logger. So I need an "adapter softare" to read the data from the sensor, convert it, and send it to the logger. All communication is through uart. Is there an easy method to create a virtual com-port in windows. The goal is that the application receives the data from the sensor, converts it, and then sends the data to the logger through a virtual com-port.
    Or, should I just build a "null-modem cable" using two usb-uart cables?
  2. picbits
    picbits Well-Known Member
    Jan 29, 2007
    2,007
    95
    Northants, United Kingdom
    I use this application extensively for serial port emulation - my laptop at work has exactly zero serial ports and often I'll use this to create two ports and emulate a whole end to end control system on the same laptop works great in virtual machines too ......
    http://www.eterlogic.com/Products.VSPE.html
    • Like Like x 1
  3. HDowns
    HDowns New Member
    May 16, 2012
    3
    1
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,304
    914
    Rochdale UK
    ONLINE
    I used to use com0com from the sourceforge site, but It doesn't work with win 8 or win 10 because of the fees Microsoft put into place for certificates to work... The cheapest one seems to be the one HDowns has linked in..
    • Like Like x 1
  6. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    I think I use two usb to uart cables and make my own "null-modem cable". And then stick both ends of that in the same computer.
  7. Ian Rogers
    Mar 28, 2011
    9,304
    914
    Rochdale UK
    ONLINE
    That's how I do it..
    BTW I have dropped C# and I now use Lazarus.. It's easier to make interfaces.... The serial modules are really good... I found the com structure used by C# difficult to use.. MIND!!! If you do use Lazarus, it doesn't autosave and Win10 doesn't ask when updating... Lost hours of programming that way...
  8. HDowns
    HDowns New Member
    May 16, 2012
    3
    1
    I'm using this method on my desktop too, but in some cases a software solution is better (laptops with 1-2 USB ports, several serial connection at the same time).
  9. Ian Rogers
    Mar 28, 2011
    9,304
    914
    Rochdale UK
    ONLINE
    My "Null modem" cable has two FTDI chips back to back so I can use com3 and com4
Share This Page
