DIY Layout Creator version 3 is here https://code.google.com/p/diy-layout-creator/
I commend it to you as a very easy program to master and use .
The program is for Windows however Linux users may be able to run it . I Use Puppy which makes me root or administrator if you like . I found by downloading the Windows version 3 and extracting the directory there is a script in there that will run the program perfectly for you .. Called " run.sh" -make it executable if necessary and run it .
Take not you must have the java JRE (Java Runtime Environment) installed but most people do I think . Its written in java .
