    Dismiss Notice
Vehicle Loop Detector
Discussion in 'Electronic Projects' started by chemelec, Jul 15, 2007.
Thread Status:
  1. chemelec
    chemelec Well-Known Member
    Apr 4, 2004
    2,122
    77
    Hedley, B.C. Canada
    ONLINE
  2. Conrad_Turbo
    Conrad_Turbo New Member
    Jan 10, 2007
    87
    1
    Thanks! I might be putting something like this in my driveway and tie it to some outside lighting. :D
  3. wizy
    wizy New Member
    Mar 16, 2007
    1
    0
    that good staf
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Hydrogenboy
    Hydrogenboy New Member
    Oct 19, 2007
    8
    0
    Just a question, but how do you make the coil? I know it says it has to be 4 - 6 feet in Diamater, and about 3 - 4 turns, but how do you make that? Do you get something that is 4 - 6 feet in diamater, and just wrap wire around it?
    Thanks.
  6. chemelec
    Apr 4, 2004
    2,122
    77
    Hedley, B.C. Canada
    ONLINE
    It Doesn't have to be That Size, But for detecting a Car, that works good.
    One Way to wind the coil: just stick some wooden sticks in the ground, with a spacing as needed, than wind the coil around them to make that diameter of a coil. When finished, tape the wires to hold them together and remove the sticks.
    Or if you want to try a smaller coil, wind it loosly around a Garbage can, than tape the wires together so thay stay as a coil and remove it from the can.
    For a Smaller Coil like this, You might need 10 to 15 turns.
    Hope this helps.....Gary
  7. Hydrogenboy
    Oct 19, 2007
    8
    0
    Yes, it helps.
    Thanks.
  8. reyarba
    reyarba New Member
    Oct 31, 2006
    11
    0
    This is interesting. I always wondered about those marks on the asphalt road at the crossings. Would be very interesting to build similar systems.
    Thanks for this project.
  9. Hydrogenboy
    Oct 19, 2007
    8
    0
    Another question (yes I ask alot!) Does the wire have to be stripped, or can it be insulated?
    Thanks.
  10. kchriste
    kchriste New Member Forum Supporter
    Jul 23, 2006
    3,677
    47
    Victoria BC, Canada
    Definitely insulated! Preferably placed inside plastic conduit or something similar if you intend to bury it in the ground.
  11. chemelec
    Apr 4, 2004
    2,122
    77
    Hedley, B.C. Canada
    ONLINE
    Any Vinal Covered wire is OK, Just buried as is.
    (Like a 16 or 18 gauge Solid house wire is good.)
  12. wmerrin
    wmerrin New Member
    Feb 26, 2007
    2
    0
    How are the magnetometer sensors used in some vehicle detector systems constructed? An example is:
    http://www.smarthome.com/7313.html
    What goes in the PVC pipe?
    Wally
  13. chemelec
    Apr 4, 2004
    2,122
    77
    Hedley, B.C. Canada
    ONLINE
    Forget the PVC Pipe. It is NOT NEEDED!
    Magnetometers use a "Hall Effect" Device to detect Magnetic Field Changes.
    This is considerably Different from my system and not very easy to build for the average person.
  14. praveen kumar singh
    praveen kumar singh New Member
    Oct 30, 2007
    1
    0
    nagpur.
    ya its great!!!!!
  15. yehey
    yehey New Member
    Aug 30, 2009
    1
    0
    Coil loop inductance
    What inductance are we looking at on this coil? I am making a mini version of this. Like a few inches, somehow I cannot get it to work.
  16. chemelec
    Apr 4, 2004
    2,122
    77
    Hedley, B.C. Canada
    ONLINE
    Aproximately 18uH.
  17. Warpspeed
    Warpspeed Member
    Sep 12, 2009
    182
    3
    Melbourne, Australia
    A better way to make really BIG buried coils is to get some multi strand data cable, and just connect all the conductors in series.
    That way, the underground loop is already waterproof, only the ends where all the connections are, needs to be protected.
    And that can be above ground, or even indoors.
  18. butyokz
    butyokz New Member
    Sep 13, 2009
    10
    0
    thanks it would really help... nice one
  19. The Mad Professor
    The Mad Professor New Member
    Mar 5, 2006
    315
    2
    Newent England
    Why stop there?
    A smaller version that could use inductance changes to detect a person would make for a really useful way of controlling garden path lights.. or even maybe dance floors...think Michael Jacksons 'Bille Jean' video.
  20. colin55
    colin55 Well-Known Member
    Feb 14, 2009
    3,534
    82
    Melbourne Australia
    The vehicle detector may work but the output of the LM393 is not connected to the LED correctly. The whole circuit could be done much simpler with a 74c14. A 4 turn coil 6feet diameter will be about 60uH not 18 uH as you suggest. Using 60uH coil and 470n capacitor produces resonance at approx 30kHz.
  21. maxmcp
    maxmcp New Member
    Nov 10, 2009
    13
    0
    Lm392n
    I am fairly new to the electronics projects scene, this project looks good, I am finding it a little difficult to find a LM393, but have found a LM392N which seems to have the same pin outputs. Does anyone know whether I could use this instead of the 393, or a good electronics supplier in the UK?
    Thanks!
    Max
Thread Status:
Share This Page
