Variable expansion with i/o ports?
eTech
Is there a way to use variable expansion (in PIC Basic) with i/o ports?
In other words, is there a way to do something like this:
Dim a as byte
a = 1
If PORTB.(a) = 1 then
'do something
Endif
eT
I think it will work. I have not used pic basic recently. The answer probably is on the PIC Basic forum. Do you get an error when you try it?
yes.
Error:
"There has to be at least one variable in the test expression"
I'm trying to write a procedure I can pass a value to flash an LED. The variable represents the port number.
So now i'm trying this approach:
Symbol led_1 = PORTC.1
Call flash_led(led_1)
Proc flash_led(ledno As Bit)
If ledno = 0 Then
High ledno
WaitUs 100
Low ledno
WaitUs 100
Else
Low ledno
WaitUs 100
High ledno
WaitUs 100
Endif
End Proc
Pic Basic Pro
OK..I guess Oshonsoft Basic isn't as flexible as other versions.
I can't do this:
Dim i As Byte
For i = 0 To 7 'loop for 8 counts
PORTB = %00000000 'make all pins low
PORTB.0 = 1 'make pin number i high <----compiler errors "Constant Arg cannot be used"
WaitMs 500 'pause for half a second
Next i
I need to be able to reference I/O pins with a variable.
Guess I'll look for a different compiler...
eT
This demo works on Oshonsoft
Dim i As Byte
Dim p As Byte
TRISB = 0x00
loop1:
PORTB.0 = 1
WaitMs 10''''''''''''''''''''added
PORTB = ShiftLeft(PORTB, 1)
WaitMs 10
Next i
Goto loop1
Dim i As Byte
Dim p As Byte
TRISB = 0x00
loop1:
PORTB.0 = 1
WaitMs 10
Next i
Goto loop1
OK...I'm not making the connection... :)
I need to be able to reference an I/O pin using a variable as the pin identifier.
I was hoping to be able to do this:
If PORTB.(i) = 0 Then
High PORTB.(i)
Endif
Is there a way to this?
eT
You only need to write a simple procedure to manipulate a port..
I just wrote a function to change any pin without altering any others
main:
	PORTB = writeport(LATB, 3, 1)
	PORTC = writeport(LATC, 2, 0)
	PORTB = writeport(LATB, 6, 1)
	PORTC = writeport(LATC, 1, 0)
Goto main
End
Function writeport(port As Byte, pin As Byte, condition As Byte) As Byte
Dim idx As Byte
Dim buf As Byte
	idx = LookUp(1, 2, 4, 8, 16, 32, 64, 128), pin  'POWER OF 2
	buf = port  'READ PORT ( LATCH )
	idx = Not idx  'INVERT ALL BUT PIN
	buf = buf And idx  'AND TO CLEAR BIT
	If condition = 0 Then  'IF PIN NEEDS CLEARING FIN HERE
			writeport = buf  'RETURN WITH ONLY THAT PIN CLEARED
			Exit
	Endif
	idx = Not idx  'OTHERWISE WE NEED TO
	buf = buf Or idx  'SET JUST THAT PIN
	writeport = buf ' ALL DONE
End Function
