    Dismiss Notice
unmanned ground vehicle
Discussion in 'Robotics & Mechatronics' started by prerna123, Oct 3, 2016.
  1. prerna123
    prerna123 New Member
    Sep 7, 2015
    4
    0
    Hi, I am working on design of an unmanned vehicle , i want to know how to choose a communication channel or device. I have to transmit 640 x 480 px at 10 frames/sec. and area to span is 500m or more Non Line of Sight. I have read about XBee will it suit my requirement ? is this calculation correct: 640 x 480 x 10~ 3mbps is the data rate. If anyone has worked on this please guide me..
  2. spec
    spec Well-Known Member Most Helpful Member
    Oct 27, 2015
    5,212
    595
    Somerset UK GMT
    Hi prerna123,
    One approach to reduce the amount of data with video is to just send change information. Of course, the benefit of this approach depends on how fast the scene changes from one frame to the next.
    spec
  3. prerna123
    Sep 7, 2015
    4
    0
    Ok, but is my way of calculating data rate correct?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. spec
    Oct 27, 2015
    5,212
    595
    Somerset UK GMT
    I assume that by 3mbs you mean, 3 Mega bits per second (3Mbs).
    3 Mbs would give one bit per pixel which would allow two logic levels, black and white say, for each pixel- a very pixelated image.
    In general, it is taken that the human eye can resolve 256 color levels, and that is the best that displays can produce too.
    As 256 levels requires 8 bits, and as a pixel is effectively made up, of three sub pixels, red, blue, and green (RGB), three bytes would be required per pixel.
    Thus, for a 640 pixel by 480 pixel display, with 8 levels for each color, you would need a data rate of: 640 * 480 * 10 * 3 * 8 bits per second or, 73 Mega bits per second.
    That is the theoretical calculations about the data rate for a high end display, but over the years the situation has become much more corrupt and manufacturers use figures for marketing advantage rather than science. This is especially the case in digital photography and camera resolutions.
    So, you need to investigate/establish what you intend to display, and what pixel bit depth you need and, also, what display standard you intend to use. I think 640 by 480 is the same pixel resolution as Video Graphics Array (VGA) which has a specifications that you will find on the net.
    spec
    PS: I see you are from India: care to tell us where and put it next to 'Location' on your user page so that it displays in the window at the left of your posts. That will be a big help to those of us replying to your questions.:)
  6. prerna123
    Sep 7, 2015
    4
    0
    Alright that means calculation is correct, so now i need to choose communication channel.
  7. prerna123
    Sep 7, 2015
    4
    0
    Thank you so much for helping me out
  8. spec
    Oct 27, 2015
    5,212
    595
    Somerset UK GMT
    My pleasure prerna123.:)
    spec
Share This Page
