We(University) bought a power system with a Wind Turbine ,Ac2DC Converter ,Charge Controller and a Battery ,
I need some help in understanding the basics of battery charging. I read about the three common stages: Bulk Charging, Absorption Stage and Float Stage, but I can't understand exactly what the controller does and how can it do it?
Let me explain my problem:
Bulk Charging:
"During the Bulk phase of the charge cycle, the voltage gradually rises to the Bulk level (usually 14.4v volts) while the batteries draw maximum current. When Bulk level voltage is reached the absorption stage begins"
Bulk Charging:
- Does it mean that the controller voltage is gradually rising so it always will be above battery voltage, while the battery voltage is rising due to the current from difference on voltage (controller-battery)?
- Can the current to the battery can be calculated by Ohm's law: (Vcontroller-Vbattery)/Battery Resistance?
"During this phase the voltage is maintained at Bulk voltage level for a specified time (usually an hour) while the current gradually tapers off as the batteries charge up"
- The controller voltage is constant, or the battery voltage is kept constant? If it is the battery voltage, how can you keep constant voltage of a battery, if flow of current is into the battery, that means increasing voltage...
- Why does the current decrease with time if the Battery Voltage is being set constant? Does the resistance of the battery increase when it's more charged?
