    Dismiss Notice
UART serial communication problem
Discussion in 'AVR' started by nafri, Mar 17, 2014.
  1. nafri
    nafri New Member
    May 3, 2012
    28
    0
    Hi all,
    I have a trouble with UART. I want tom make AVR programing to get UART communication via USB. I also use terminal. exe to sent data, firstly my plan is that I sent to Arduino a char and receive integer like '1'. it can be quite simple but I can not make this. Also every documents make echo which is sent a char and come back same char I also make this and also I have problem with this because when I write terminal ' a ' it can sent it back but when I write 'c' it sent another char such as 'b ' how can I tackle this problem. thanks for your attention....
  2. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,917
    1,097
    Baud rate is wrong. # Start bits wrong. #of Stop bits wrong, Wrong data length, Parity (odd, even or none are options), wrong handshake signals.
    Some of my older techniques is to loop back the data, that at least tells you you can send.
    Did a lot with RS232 since 1975 or so, You always needed an expensive little box that could re-route any signal and you had lights for every signal. Then IBM went 9 Pin any really messed stuff up.
  3. nafri
    nafri New Member
    May 3, 2012
    28
    0
    ok.. thanks for your reply now I solve the problem but when I write 'a' it always send "1" it enters the infinite loop I think Icansolve this problem with udr0. if I can clear inside the UDR0 after send.I beleive it can exit the infinite loop. how can I clear inside of the udr0.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ikalogic
    ikalogic Member
    Dec 27, 2003
    834
    14
    Limoges, France
    Can you share your source code?
  6. kubeek
    kubeek Well-Known Member
    Mar 11, 2006
    1,488
    186
    Prague, Czechia (not Chechnya)
    The way I setup UART is that I keep sending a character or string in a loop within the microcontroller, and then I try setting up the baud rate so that the computer can receive it. Also you might wanna look at it on an oscilloscope.
Share This Page
