    Dismiss Notice
UART communication between atmega128 and arduino UNO
Discussion in 'AVR' started by nranawat, Apr 9, 2014.
  1. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    I am trying to do UART communication between atmega128 and arduino UNO. Both are running at 9600 baud rate( checked both by doing serial communication with laptop using xbee radios from zigbee),but i am not receiving data properly. The data is following some pattern but i am not able to understand the relation.The lower four bits are always correct but upper four bits follow some weird pattern.
    should receive---------actual received
    1------------------------9
    2------------------------A or 8
    3------------------------B or 9
    4------------------------8 or A
    5------------------------9 or B
    my atmega128 and arduino code are as follow: arduino sends one value and atmega128 displays the recieved value on array of 8leds on PORTA.
    Arduino code
    void setup()
    Serial.begin(9600);
    Serial.write(33);
    void loop()
    Atmega128 code:
    #define F_CPU 16000000UL
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #include <util/delay.h>
    #include <stdio.h>
    volatile unsigned char tdata, rdata;
    void USARTInit()
    UBRR0L = 0X67;
    UBRR0H =0x00;
    UCSR0C= ((1<<UCSZ00)|(1<< UCSZ01));
    UCSR0B=(1<<RXEN0)|(1<<TXEN0)|(1<<RXCIE0);
    ISR(USART0_RX_vect)
    rdata = UDR0;
    PORTA = rdata;
    void init_devices()
    cli();
    DDRA =0xff;
    USARTInit();
    sei();
    rdata=0;
    int main(void)
    init_devices();
    while(1)
  2. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    Have you connected the grounds of the two microcontrollers together?
    Is that value "33" supposed to be hexadecimal, or decimal?
    Could you give more examples of data send and what you receive.. include code.
  3. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    yes ground is common, 33 is decimal value... for 31 it gives 8E, 32 ---8F, 33 ---91 for 1 it gives 81, 2--- 82, 25 ---99, 26--9A, code is same have just changed value in serial.write.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    So, the lower four bits are not always correct.. You seem to have the MSB always 1 at the receiving end.. that makes me suspect a baudrate mismatch.
    .. although the first two pairs you listed tells otherwise.
    How long wire do you have between the two?
  6. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    yes the problem is with baud rate only as in case sending 33 in a loop it gives 81 sometimes and 91 sometimes.
    I have checked default fuse bit settings for arduino here. so it is set for 16mhz external crystal only.
    For 128 i have used the fuse bits as: lfuse:FF, hfuse:99 (settings for 16mhz external crystal)
    for register settings of 128 i have posted my code above.
    What else i should be checking to make my baud rate correct?
  7. kubeek
    kubeek Well-Known Member
    Mar 11, 2006
    1,491
    186
    Prague, Czechia (not Chechnya)
    ONLINE
    Can you check the data with an oscilloscope? That should get those problems sovled in about ten minutes.
    Also as misterT asked, how are the two micros physically connected? How long is the wire?
  8. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    unfortunately i do not have oscilloscope with me.
    have connected tx of one with rx of other and vice versa and a common ground... wire length is around 10 cm .
  9. misterT
    Apr 19, 2010
    2,697
    368
    Finland
    Could you do one test.. send these 8 messages from the arduino to the atmega128 and post what is received. And do it many times in a loop with a delay between transmissions... I do not like the fact that you are sending one message after reset and then nothing. Make a loop that sends the same character over and over again, with 200 ms delay between sends.
    send these:
    Serial.write(0b00000001);
    Serial.write(0b00000010);
    Serial.write(0b00000100);
    Serial.write(0b00001000);
    Serial.write(0b00010000);
    Serial.write(0b00100000);
    Serial.write(0b01000000);
    Serial.write(0b10000000);
    .. you get the idea.. post what was received after each of those.
  10. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    The MSB is always high as you said
    the output is :
    0b10000001
    0b10000010
    0b10000100
    0b10001000
    0b10010000
    0b10100000
    0b11000000
    0b10000000
    for 0b00000000 it gives 0b10000000
  11. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    hey.. my code is working now....
    i tried my code with internal clock of atmega128 and it is working fine, it means the problem was with my extrnal crystal.. do crystals start work slowly after some time.. i ran a code for led blinking in 10s using _delay_ms function in loop and measured the time using stop watch it was coming more than 11s...was my external crystal the actual problem ??...i cannot just accept the idea of crystal running slow after sometime....
  12. kubeek
    Mar 11, 2006
    1,491
    186
    ONLINE
    Do you have the oscillator fuse set properly to match your crystal? Can you post a circuit diagram?
  13. skimask87
    skimask87 Member
    Mar 23, 2014
    128
    10
    Logan (Minot), ND
    Possible, if you don't have the correct load caps connected to it, and/or it's been abused (eg. dropped, frozen, burned, twisted, shanked, pounded, beaten, stuffed, licked, kicked, verbally rebuked, etc)
  14. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    my fuse bit settings for external crystal were lfuse:FF, hfuse:99 , calculated from here and cross checked... i can draw the exact ckt diagram as i am using a development board bought online(here) and crystal arrangement is below the small PCB of atmega.
  15. skimask87
    skimask87 Member
    Mar 23, 2014
    128
    10
    Logan (Minot), ND
    You didn't happen to notice that the ATMega128 board is using a 14.7456 Mhz crystal did ya?
    And your code is set up for a 16Mhz oscillator frequency...
  16. kubeek
    Mar 11, 2006
    1,491
    186
    ONLINE
    I would just try replacing the crystal and see what happens.
  17. skimask87
    skimask87 Member
    Mar 23, 2014
    128
    10
    Logan (Minot), ND
    Ya, with a 16Mhz crystal.
    16Mhz = ~8.5% faster than 14.7456Mhz
  18. kubeek
    Mar 11, 2006
    1,491
    186
    ONLINE
    Seems we cross posted. Any crystal with known frequency would do just fine. Or he could put the correct value of the actual crystal into the code.
  19. nranawat
    nranawat New Member
    Apr 9, 2014
    8
    0
    damn... my code was for 16mhz.... took 16m for granted.......
Share This Page
