    Dismiss Notice
Tutorials for PIC?
Discussion in 'Microcontrollers' started by falleafd, May 20, 2003.
  1. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
    Do you know somewhere there are tutorials for PIC? A really good tutorials from basic to adv.
    Thanks muchie
  2. Skyknight
    Skyknight New Member
    May 1, 2003
    97
    0
    Spain
    I think the best tutorial is the datasheet itself. I haven't found any tutorial about PICs that finally result usfull. There are several on Internet, but mainly for begginers. I think the best you can do is to cut the program in many short tasks, procedures or routines, just as a diagram. After that, writing the code gets much easier. If you have any trouble ask us.
  3. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Scubasteve
    Scubasteve New Member
    Apr 6, 2003
    176
    0
    Ontario, Canada.
    The one is also pretty good
    http://www.piclist.com/techref/microchip/intro/pic.htm
  6. robinvan
    robinvan New Member
    May 12, 2003
    1
    0
  7. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
    Thanks for your help.
    I knew some basic concepts. Perhaps, I'll ask for your help when I finish my program.
    I'm writing a program to drive a stepping motor via ULN2003. I'm sure it'll have many mistakes, and I hope you may help.
    Thanks again for your help. It's very kind of you all.
  8. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
    I wanna use 5 registers to save value of velocity, accelerate and numberof steps.
    And I only use 5 low bits of each register to save data.
    one register for velocity
    one for accelerate
    and 3 for number of steps, so I'll have 15 bits for number of steps
    the highest bit of velocity register will show the direction that the stepper should turn
    My command should come as
    mm|c|ddddd
    mm is select the PIC (I have 2 PIC to drive 2 motor- left and rite)
    if c = 0 then select the register with ddddd
    if c = 1 then send data ddddd to the active register
    I use parallel port to send commands.
    data 0 to data 7 of parallel port is connected to rb0 to rb7 of PIC16F628
    Questions:
    1) How do I select register using my command?
    For example I choose 5 register addressed at... in bank 0
    2) How do I count number of steps if it is saved in 3 different registers?
    3) I wanna send data to 4 pins RA0 to RA3 of PIC to ULN2003, for example sending 9 (1001)
    how should i write?
    bsf porta,ra3
    bcf porta,ra2
    bcf porta,ra1
    bsf porta,ra0
    but if I wanna send all 4 bits at a time, how should i write?
    4) assuming that the velocity register is at 0xMM
    so when i check for direction, I should write:
    btfss 0xMM, 04 (the highest bit of 5 bits data of this register will show direction)
    goto turnleft (if direction = 0 then turn left)
    goto turn right (if direction=1 then turn right)
    is this rite?
    5) this will be similar to accelerate register,
    if the highest bit is 0 then accelerate
    if it is 1 then decelerate.
    Deeply thanks
  9. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
  10. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
  11. Skyknight
    May 1, 2003
    97
    0
    Spain
    Good page, good job!
    Thank you!
  12. moki
    moki New Member
    May 28, 2003
    20
    0
    Durban, South Africa
  13. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
    Thanks indeed
    However, I'm in Vietnam and I cannot pay via internet.
    I tried to program with asm on PIC, and it worked quite good. It's oki to me now.
    But these near days, I got a problem on driving stepping motor with various number of steps, velocity and acceleration. I solved this problem on paper, but to compute the delay time after each step, it needs a complex mathematical formula with *, /, ^ (+,- is easy to do in asm). I don't know how to do.
    I thought I should write in C then compile it.
    However, I'm a newcomer in microcontroller field, Pls show me step by step how to program with C?
    Which programs I need to use? Is there any tutorials on PIC C?
    What is the difference between C17 and C18 compiler of microchip?
    I'd like to program for 16f628.
    Deeply thanks
  14. moki
    moki New Member
    May 28, 2003
    20
    0
    Hi Falleafd :)
    Sorry for replying so late! I am not very familiar with C. Check out the following sites for some other useful info.
    http://www.piclist.com/techref/piclist/codegen/delay.htm (this one automatically produces code for time delays)
    http://www.winpicprog.co.uk
    http://www.ke4nyv.com/picprojects.htm
    http://www.mastincrosbie.com/mark/electronics/pic/stepper.html (exactly what u want!!)
    http://www.fritsche.com/dave/notebook/pic/c2c/steppermotor/stepper.html
    I hope this is of some help to you!
  15. olly_k
    olly_k Member
    Jul 5, 2003
    236
    1
    UK
    I think the EPE V2 cd is available with COMPRAHENSIVE C course (see links posted above) I prefer assembler personally I think you get to know the micro slightly better and make tighter code. I sound a bit of an expert lol but I AM NOT!
    I used pictutor 'assembler' v1. That was good V2 should be much better.
  16. falleafd
    falleafd New Member
    May 13, 2003
    412
    0
    Vietnam
    Thanks muchie for all.
    I also have some questions bout directives that I posted on this forum, but noone answer meeh. May you help me about this?
    By the way, I'd like to ask more bout macro, may you tell me bout the basic concepts of macro when writing in MPASM?
    Deeply thanks.
Share This Page
