    Dismiss Notice
Toggle switch question
Discussion in 'General Electronics Chat' started by Switch, Nov 26, 2009.
  1. Switch
    Switch New Member
    Nov 26, 2009
    4
    0
    Right.
    Toggle switches
    What I need is a toggle switch, 3 locking positions. ie ON-ON-ON.
    but What I need is it for be all fed from 1 input.
    So 1 to 3
    So that it selects between 3 inputs.
    almost every toggle switches i've found do THIS
    [​IMG]
    Which is not what I need.
    Does what I want exist? or will I have to bodge it with relays and diodes?
    I only need a single pole switch (switching one connector, not a pair)
    Help!
  2. shortbus=
    shortbus= Well-Known Member
    Mar 23, 2008
    1,230
    77
    youngstown, oh
  3. Switch
    Switch New Member
    Nov 26, 2009
    4
    0
    I might be very dim. But I cant find what I need.
    Symbolicly it would look something like this
    [​IMG]
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Vizier87
    Vizier87 Active Member
    May 12, 2009
    1,495
    12
    Johor Bahru, Malaysia
    hmmm. Mechanical relays are bulky and power hungry. What is your application? Switching motors?
  6. Ross Craney
    Ross Craney New Member
    Dec 11, 2002
    218
    1
    Australia
    you can get SP3T (single pole triple throw) switches in slide or rotary. You can get triple throw toggle switches BUT the centre position was always OFF.
  7. Switch
    Switch New Member
    Nov 26, 2009
    4
    0
    ok,
    its to handle a few LED's each, so we're not talking huge currents or voltages
    what the switch needs to do is select
    Position 1 - Set A
    Position 2 (middle) - Set A and B
    Position 3 - Set B
    (obviously I could just do this with 2 simple toggle switches, But I like the idea of 3 position toggle), obviously with an On-Off-On (easily available by contrast) I could Jury-rig it to supply power to both sets when Pos 1/3 were not selected (using a relay)
    Edit: Slide and Rotary exist obviously. But I'd like Toggle... looks like its relays or logic gates for me...
  8. Mike_2545
    Mike_2545 Super Moderator
    Jan 4, 2009
    1,057
    29
    Toledo, Ohio
    • Like Like x 1
  9. Switch
    Switch New Member
    Nov 26, 2009
    4
    0
    £23 for 2 of them including PnP?!!!! damn
  10. microtexan
    microtexan New Member
    Mar 28, 2008
    352
    6
    Texas
    Wouldn't a 3 position toggle switch have 4 connections or pins?:confused:
  11. Mike_2545
    Jan 4, 2009
    1,057
    29
    Toledo, Ohio
    Images are for reference only
    See Product Specifications
  12. Vizier87
    May 12, 2009
    1,495
    12
    Huh? You're switching LEDs with relays? ....a microcontroller will be much better.. they should cost less than 10 bucks if you're using the Microchip's 16F series.
Share This Page
