Test adapter for 6Eu7 and EF86 tubes
diy didi
I have a valve tester that can test 12AX7 tubes etc.
i would like to be able to test other 9pin tubes such as the 6EU7 and EF86 tubes.
Can anyone tell me how to make an adapter for each if these for my tester?
Find an online copy of the RCA Receiving Tube Manual (like this), look up the respective tubes, and map the pins...
My emphasis.
By "etc.", does that mean the tester has the ability to check other tubes as well?
Reason I ask is that I've never seen a tube tester that will check only one tube type. They all had various sockets and switch selections for filament V, biasing, etc. to accommodate a pretty wide range of tubes.
If your tester will test pentodes and is able to supply 6.3v heater voltage then it probably will test the Ef86, look through the data for the tester and find a pentode test that is similar to the Ef86, you can get b9a plugs & sockets on ebay, you might even get lucky and find a test function that has the same pinout.
