Bobdragon12
I'm hoping to get some help with a Hottub issue , My hottub had a temperature issue and I replaced the probe , it now reads 10deg lower than it should 25.5deg C on the display 35.5C in the water . I can obviously add resistance but this pushes the temperature the wrong way . Any suggestions as to something I could put in line to correct this ?
Also the sender is not raising correctly it takes more heat than it reads to make the probe work
Any help appreciated Jon
