TDA 2006 Amp
boscoe
Just wanted to know what sort of caps I'm supposed to use for this circuit. If someone could could they tell me every component please as I'm not quite sure. Thanks a lot.
Boscoe
I'm not really sure about your question.
Well, the caps that har two thick close lines has no polarity. The other type wich has one black and one filled white is polarized caps. That is white line is the positive terminal and black line is the negative terminal.
The capacitors larger than 1µF are electrolytics and the capacitors less than 1µF are film or ceramic capacitors, voltage rating greater than +Vs.
