Boncuk
Just curious, are NiCd batteries still available in the EU?
Haven't been in Germany for more than four years.
They are available in Thailand.
Exactly, the amount of heat that can be dissipated depends on the surface area exposed to the air which is exactly why cable has a lower current capacity when wound into a tight coil than it does when unwound.If heat dissipated to the air is proportional to surface area, then the surface area of a cylindrical winding of wire should raise the fusing current of an individual wire conductor, provided that there is good thermal conductivity between the conductors in the winding.
That's true but it would melt at a much lower current.There will also be more thermal inertia in a winding than in an individual conductor, which would delay the time it takes to melt.
An extension reel is an extension lead that rolls up, usually into the socket end, which in some cases has more than one socket on it (often 2 or 4). Another type of extension reel hangs near the plug end and permits the user to draw the cord out by grasping the socket end. It should be noted that these cables can only be used to carry full rated current when fully extended since the portion on the reel constitutes a concentration of the loss power (the result of its series resistance) which is not suitably dissipated unless most of the cable is unreeled to expose it to ambient air.
A 3-million-ampere current pulse creates a 240-tesla magnetic field at the loop’s center, generating so much heat and magnetic force that the loop explodes.
Alkaline batteries blow up or leak when their capacitance is charged. The "charge" lasts for a very short time even if it is not used.
... since the ni cad batteries i was using became horribly unreliable. they don't last as long as when they come out of the factory ...
what has the shape do it with it.Explain?I think if the core of the electromagnet is a "U" shape with the ends fairly close together then it will be a strong magnet. Maybe make the core like a speaker where the center pole is surrounded by the other pole so it has a lot of space to hold many paper clips and it has both poles of the magnet to be very strong.
