    Dismiss Notice
steel vs copper or brass in tesla coil
Discussion in 'High Voltage' started by lokeycmos, Jul 16, 2012.
  1. lokeycmos
    lokeycmos New Member
    Oct 17, 2011
    188
    0
    ive heard from a couple of my viewers that i should not use steel as a conductor on my tesla coil, that i should use copper or brass instead. i would like some input on this from more experienced people. please elaborate! i am using steel strapping for my cap bank as well as steel 'L' brackets and screws in my spark gap. im also using steel screws in my richard quick spark gap. any input is welcome!!
    http://www.youtube.com/watch?v=hh3vilo6OL4&feature=plcp
    http://www.youtube.com/watch?v=mVsZIFiDD0o&feature=plcp
  2. johansen
    johansen Member
    Mar 11, 2009
    187
    15
    if the caps get warm but the steel doesn't then you're probably fine. but if the steel gets warm before the capacitors do then you should see an improvement by switching to copper, brass, aluminum or practically anything nonmagnetic.
    the issue with steel isn't the conductivity (which isn't that un acceptable if you just use a lot of it.) but the permeability which further reduces the skin depth.
    another thing you might consider doing is cutting the primary in half and configuring the capacitors for double the capacitance/half the voltage.
    i don't know what the numbers are for your tesla coil but you may not have enough KVA in the primary tank.
  3. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    Steel brackets and strapping for parts shouldn't be a problem, provided it's well-insulated and won't conduct. Steel in the spark gaps isn't a huge problem, but you'll need to watch the surface of the contacts for damage. Sharp edges around "craters" caused by the sparks could prove to be a problem. Just keep it clean and smooth and you'll avoid energy loss.
    I would NOT recommend that for several reasons. First, depending on the voltage of your capacitors, halving the voltage tolerance would be a bad idea. It's a good way to damage them. It would also reduce the efficiency of the coil. Even if the tank circuit is in perfect tune with the secondary, the coil won't work correctly unless the capacitor is properly matched to the transformer. In an AC Tesla coil setup, the spark cap discharges every half cycle. If the capacitor and transformer aren't properly matched, the capacitor might not have enough time to fully charge before being discharged into the primary. This will make the coil much less efficient and it will not work properly.
    From prior discussions, I know that lokey's transformer is a 15Kv 30mA. According to the formula, [​IMG], where C is the matching capacitance, Z is the impedance (transformer voltage/transformer current), and Fl is the line frequency (60 Hz), the tank capacitor value he needs is about 5.3nF. Removing too much will make the coil operate incorrectly. Overall, I would get a capacitance as close to the calculated one as possible and go from there.
    Tesla coils are very touchy--one thing even slightly off can make the entire thing not work. Patience is key ;)
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. johansen
    johansen Member
    Mar 11, 2009
    187
    15
    I think he has 8.6nF so it would probably make sense to put the 4 caps in series-parallel rather than parallel.
    might need more turns on the primary though, idk.
  6. DerStrom8
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    He originally had 9.15nF, with four caps in parallel. After removing one, which he did earlier, he's left with approximately 6.9nF. He could probably get even closer to the necessary value by taking another one off, bringing it to 4.6nF, and have a slightly longer primary to keep the tank circuit at its resonant frequency. Putting the four caps in series-parallel would only give him about 2.3nF, which is nowhere near enough.
    His primary is definitely long enough to allow him to tap it wherever needed. I don't think he'll need to make it longer at all.
Share This Page
