    Dismiss Notice
some questions....
Discussion in 'General Electronics Chat' started by bogdanfirst, Mar 13, 2003.
  1. bogdanfirst
    bogdanfirst New Member
    Dec 13, 2002
    1,310
    1
    Ramnicu Valcea, Romania
    if i think of a bipolar trnasistor, it has 3 areas.p,n,p or n,p,n that means that they are like 2 diodes connected with the anodes or cathodes together....
    but in real life if i connect 2 diodes like this, do they work as a transistor?
    and another thing about tolerances....
    lets say.....if i got a resistor with a 2% tolerance and one with 5%, 2K and 3K. i connect them in series. i get a resistor 5K, with what tolerance?
    2000*0.98=1960; 2000*1.02=2040
    3000*0.95=2850; 3000*1.05=3150
    so i will have a resistor with the value of 4810-5190, wich means 5K+190R/-190R so i get 5K+/-3.8%
    am i right?
    and if i have them in paralel......a littel bit more complicated, but do i have it right since now? if yes, then ill continue with the paralel.
  2. Mat
    Mat New Member
    Feb 27, 2003
    22
    0
    Scotland
    NPN/PNP JUNCTIONS
    Are you sure. :D
  3. bogdanfirst
    Dec 13, 2002
    1,310
    1
    if i am sure about what?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. pebe
    pebe Member
    Sep 24, 2002
    354
    1
    Ellon - Scotland
    Two diodes do'nt make a transistor.
  6. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Two diodes can't make a transistor because of several reasons which are,
    1) Doping levels of both diodes are almost same whereas a real transistor has heavily doped emitter, mediumly doped collector and lightly doped base.
    2) Physical area of all three semiconductor layers in two diode configuration is same whereas in real transistor collector has the largest area and then comes emitter and base in descending order.
  7. bogdanfirst
    Dec 13, 2002
    1,310
    1
    i thought so.
    thanks. but what about the tolerances, am i right?
  8. Gene
    Gene New Member
    Feb 18, 2003
    379
    0
    Georgia
    I don't see anything wrong with your calculations. However, if tollerences are critical to your circuit, recommend you actually measure the resistor circuit you build with a good ohmmeter.
  9. bogdanfirst
    Dec 13, 2002
    1,310
    1
    yes, thats right, but i was just doing these calcs for curiosity.
    i am not sure but if i use the, in paralel, i wouldnt have a tolerance like x ohm +/- y %. i think it will be like x ohm, +y%/-z% i mean +something and - another thing.
    am i understood?
  10. Gene
    Gene New Member
    Feb 18, 2003
    379
    0
    Georgia
    If it couriosity, why not do what you did in the first example? Figure the parallel circuit (1200.048). Then, apply the tollerance to the two resistors and re-calculate the circuit (1161.440). The tollerance is 3.32% (wish I had a good calculator here)!!!
Share This Page
