    Dismiss Notice
(solved)Odd behaviour with 74165 PiSo (paraller in, serial out)
Discussion in 'Arduino' started by fezder, Apr 14, 2017.
  1. fezder
    fezder Well-Known Member
    Dec 11, 2011
    1,665
    100
    Mikkeli, Finland
    Right,at first I thought this chip is easy to use. Turns out, something odd is going on here.
    I had it correcly hooked in my understandig, but wrong wiring gives me right results! I know....but read on.
    first off code, It's small, and used only 3 pins (which is one confusion, I should use clock_inhibit, but I have it hooked on GND)
    Code (c):
    byte PISOdata = 3; //input from SiPo
    byte PISOlatch = 4; //latch for SiPo, LOW=load
    byte PISOclk = 5;  //SiPo clock
    byte PISOreceivedData;
    void setup()
      pinMode(PISOdata, INPUT);
      pinMode(PISOlatch, OUTPUT);
      pinMode(PISOclk, OUTPUT);
      Serial.begin(9600);
    void loop()
      digitalWrite(PISOlatch, LOW);    //load register
      digitalWrite(PISOlatch, HIGH); //register at high, to allow reading
      for (byte i = 0; i < 8; i++)
        digitalWrite(PISOclk, LOW);
        digitalWrite(PISOclk, HIGH);
        Serial.print(digitalRead(PISOdata));
      Serial.println();
    Now then, the confusion. IF it short serial-in (pin 10) from '165 to gnd, not using it, no matter what I do, I always lose one bit of data.
    Then, I figured to start laying "button" signals from lm3914 (used it as knob-controlled button-array of sorts) starting from SERIAL-input pin of '165, and guess what? Now I get all data I want! . But any clues, why not when It was hooked correctly?
    datasheed for you:
    http://www.ti.com/lit/ds/symlink/sn74165.pdf
    Anyone willing to test this?
  2. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,792
    134
    morristown,tn
    This may help you
    [​IMG]
    • Thanks Thanks x 1
  3. BobW
    BobW Active Member
    Apr 28, 2010
    501
    52
    Canada
    As soon as you latch the parallel signal in, the first bit is immediately available at the serial output. So, you must read it before toggling the serial clock. This is different than many other serial devices that require a clock signal before reading the first bit.
    • Thanks Thanks x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. fezder
    Dec 11, 2011
    1,665
    100
    Mikkeli, Finland
    Thanks for both of you. Circuit for each input is like this, except resistor is 1k. Signal is taken from collector, and signal levels are within threshold values. (not in "gray" area).
    https://i.stack.imgur.com/5M7jX.png
    To be more specific, here's SN74HC165 (what I have) datasheet, http://www.ti.com/lit/ds/symlink/sn74hc165.pdf
    Also, this new datasheet shows more information like application notes and timing requirements.
    I see what I can do with code to read one bit before start toggling clock. Didn't think of that! Is this detail mentioned in datasheet somewhere?.
  6. fezder
    Dec 11, 2011
    1,665
    100
    Mikkeli, Finland
    Yes, that did the trick, thanks BobW !. Here's final, working code. :)
    Code (c):
    byte PISOdata = 3; //input from PiSo
    byte PISOlatch = 4; //latch for PiSo, LOW=load
    byte PISOclk = 5;  //PiSo clock
    void setup()
      Serial.begin(9600);
    void loop()
      Serial.print(digitalRead(PISOdata)); //here's the extra reading you suggested
      for (byte i = 0; i < 7; i++) //also changed this from i<8 to i<7 since there was excess 0 at data.
      Serial.println();
  7. BobW
    BobW Active Member
    Apr 28, 2010
    501
    52
    Canada
    The datasheet doesn't point it out specifically, but it's clear from the internal logic diagram that's shown on the datasheet.
    The simplest way to deal with this is to put the clock toggle logic at the end of your read loop instead of the beginning.
Share This Page
