    Dismiss Notice
Solar Panel Help!
Discussion in 'Alternative Energy' started by chriskid, May 25, 2009.
  1. chriskid
    chriskid New Member
    Mar 30, 2009
    8
    0
    hi, i have recently built a small 18w solar panel and am quite confused. When i try to measure the current of the solar panel in just daylight it produces only 5ma and sometimes i measure it straight afterwards and it would give out 100ma in the same daylight. I was thinking this was due to a connection that might be not quite good enough in the solar panel because it doesnt gradually go from 5ma to 100ma, it just shoots straight up to it when nothing outside as changed in light intensity?
    thanks from chris
  2. Willbe
    Willbe New Member
    Aug 16, 2008
    1,236
    7
    MD
    Intermittent connection in your panel or your ammeter or both.
  3. M_ASIF263
    M_ASIF263 New Member
    May 25, 2009
    1
    0
    hi i want to make soler pannel at my home plese tell me what requirements for that and how i can made it thanks.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    Broken cell?
  6. chriskid
    chriskid New Member
    Mar 30, 2009
    8
    0
    I Noticed
    I Noticed that two of the cells in the solar panel have splits/ cracks going to the middle of the cell. Do these cracks have an effect on the solar cell even though its not completely split in half? since this might the reason why it was doing the thing earlier.
  7. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    Yes, it will effect it. Depends on how the solar array is wired internally, it's probably some combination of series/parallel panels, you may not be able to bypass the cracked cell, which means you should probably buy a new panel.
  8. chriskid
    chriskid New Member
    Mar 30, 2009
    8
    0
    so with a cracked cell when the cells are parallel is it worth changing the cracked cell for a spare? or is there only minimal change in how well the cell works because of the crack?
    thanks from chris
  9. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    If it's an 18watt solar panel it's a combination of series and parallel cells, you could try using a conductive glue to seal the crack, but I have no idea what that'll do to the long term reliability of the panel. If you have the funds or a replacement you can use I would recommend simply replacing it, and contacting the maker of the panels to see what kind of repair/patch method they might suggest.
Share This Page
