    Dismiss Notice
Solar Concentrator
Discussion in 'Renewable Energy' started by crashsite, Jan 5, 2008.
  1. crashsite
    crashsite Banned
    Nov 20, 2007
    725
    3
    First, let me apologize that this post is a bit long-winded. But, in an effort to head off extraneious and redundant input (good luck on that, huh?).....
    Last summer a steam pipe under the streets of New York City burst. I was unaware of why there was live steam being piped around the city in the heat of summer. An internet search gave the answer. Several, actually. One was that the steam was used for facilities cooling.
    It's always seemed counter-intuitive that the first step in removing heat is to add even more. For example, the flame in a gas refrigerator or the compressor in an air conditioner. But, I know the basic physics and it makes some sense. But, the secret is not the addition of heat, it's using the heat energy to create a thermal differential.
    The modern home is essentially an insulated box. In the winter, the insulation keeps the heat that's generated by stoves, heaters, furnaces and mammals (people and pets) inside the living area. Pretty easy and logical. But, in the summer, the insulation is used to keep the heat out. Then, even more heat needs to be generated to power the air conditioner to cool it off.
    Of course, the problem is that the sun beats indescriminately on the roof of the house and surrounding areas. There are some thermal gradients (shade under trees, ponds and pools, etc.) but, they are too generalized and too slight to be effectively utilized.
    If a solar concentrator could be put...say...on the roof, it would serve two purposes. One is that it would shade part of the roof and the second is that it would concentrate the sunlight into a small area. We've all charred a piece of paper with a magnifying glass so this is readily understood. If a series of parabolic reflectors werre used, the area of the reflector would shade and the sun's light would concentrate onto a small target. If a series of fresnel lenses were used, again, it would effectively shade most of the roof while concentrating the light onto a small target.
    That action does create a substantial thermal gradient. By passing a working fluid (coolant) throught the hot section, it would gain energy and then when brought to the cooler, shaded area, allowed to expand in a heat exchanger, you basically have a "gas refrigerator" without the gas flame. Then it needs only a low-power fan and ducting to distribute the cooled air into the home.
    The amount of energy available is substantial. A rule-or-thumb is that strong, direct sunlight provides about 1kW per square meter. My house is about 1400 sq. feet and my garage is about another 600 sq. feet. Divide that by 27 (to stay in the English system) and cut that in half to give a conservative estimate (I'm somewhat more northern than the "hot belt" of the US) and, during the hot part of summer days, there's about 35 kW equivalency there.
    My furnace is 20 kW and my wood stove....I can't even begin to convert. Bottom line is that even a small fraction of that 35 kW could be used to substantially cool my house (ie: covering only part of the roof with the apparatus and the inherent conversion inefficiency of it).
    Complexity of the apparatus could be minimized by reducing or eliminating moving parts (sun tracking). It would only have to work during the hot part of the day. That would be late morning to mid afterneoon. The insulation in the home could hold the cool air in til the sun sets and things cool for the night. But, of course tracking could still be used, even in a simplified form (of which there are many possible options).
    So, the true bottom line is...why isn't this commonly done?
  2. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    It can be done but I don't know if it would be better to use a solar panel to run a compressor based air conditioning unit.
    Out of your 35kW of solar power you'll probably only be able to extract 20% at the most.
    The amount of cooling power that will give you depends on the temperature differential between the inside of your house and the outside.
    You could make the system more efficient, if you use the waste heat to heat water.
    I imagine that this is not often done because it's fragile and high maintenance as you need to clean the reflectors quite frequently.
  3. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,022
    317
    Brisbane Australia
    I am also amazed that these systems have not been commercialized.
    Here is an article from 1996 about an ammonia absorption system.
    You may also want to google Lithium Bromide absorption systems.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    ONLINE
    Probably because they aren't viable?.
  6. justDIY
    justDIY Active Member
    Mar 1, 2005
    1,723
    12
    Michigan, USA
    in the movie mosquito coast, a western inventor / scientist went crazy and forced his family from their suburban home to live in the jungles of south america. he brought air conditioning to the savages in the form of a wood fired ammonia absorption chiller. all was well till some pirates showed up, shot up the place, and then caused a big explosion when the ammonia tanks ruptured. I'm sure Hollywood exaggerated things with the help of gasoline, but thats the main reason ammonia isn't used much any more, it's a tad bit flammable
  7. Nigel Goodwin
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    ONLINE
    Are you sure ammonia is flammable? - my school chemistry days are a LONG time ago, but I don't recall it was so? - could be wrong though?.
    More likely it's just the American film makers usual imagination that ANYTHING you shoot blows up! :p
  8. crashsite
    crashsite Banned
    Nov 20, 2007
    725
    3
    I don't know about that. I think they're pretty accurate. Like in the movie, "Them" when the ants make a ring around the outside of a car generator, with their bodies and shorted it out with a good deal of pyrotechnics. Please tell me at least THAT wasn't fake.........
  9. justDIY
    Mar 1, 2005
    1,723
    12
    Michigan, USA
  10. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
  11. Pommie
    Mar 18, 2005
    10,022
    317
    Brisbane Australia
    Ammonia isn't used anymore because anhydrous (or even just concentrated) Ammonia is a nasty substance to have around. That why I mentioned Lithium Bromide (and Chloride) absorption systems which are much safer.
    Here is a paper on solar powered LiCl aircon for anyone that's interested.
  12. rjvh
    rjvh New Member
    Dec 20, 2007
    863
    6
    cambodia
    the problem with the most alternative energy sources is that they are not 24/7 hours/days availible that needs than a form of storage because it seems that the consumption is always out of phase with the supply
    the storage is now these days the big cost factor to make
    add also the poor efficiency of transfering energy to an other form and it's clear that it is nice for a hobby but comercialy it still has to go a long way
    it's a hobby for me but to sell it you can not compete
  13. crashsite
    crashsite Banned
    Nov 20, 2007
    725
    3
    But, this is the exception to the rule. It's most effective at the times it's needed most and is also at maximum power when maximum cooling is needed. It just seems like that much raw energy should be pretty easy to extract and put to use and I don't know why it's not routinely being done. But, maybe a better question is, "If I'm so darned smart about it, why haven't I done it?".
  14. Nigel Goodwin
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    ONLINE
    Try it and see? - I suspect you will find that it's NOT easy to extract :D
  15. crashsite
    crashsite Banned
    Nov 20, 2007
    725
    3
    Shiftless Bum
    Oops, did I forget to mention the sinfully lazy part, too?
  16. rjvh
    rjvh New Member
    Dec 20, 2007
    863
    6
    cambodia
    the case of heating amonia in a pipe and condens it in the chloride solution that hapens in the day cycle to evaporate it again and that is the moment that you extract heat from (your room) the suroundings where you did store the liquid amonia/chloride solution that is thus after the day cycle and that is mostly the time of day that it will cool down already
    for making an ice machine this works wel but cooling your house on the hottest moment of the day no
    this is the working of an passive machine (no energie put into it from your side)
    if you make a machine with a constant circulation in it it consumes already power for pumping the media through
    than you have a the same as a fridge or an aircon
    an active system is much more work and costs to maintain also
    why do we use amonia chloride solution ?
    this is only because it is capable of holding a good value of energie
  17. Pommie
    Mar 18, 2005
    10,022
    317
    Brisbane Australia
    We don't use Ammonium Chloride.
    We use either,
    Liquid Ammonia and Water in a Hydrogen atmosphere.
    or,
    Lithium Bromide and water.
    or,
    Lithium Chloride and water.
    The nice thing about Lithium (Br or Cl) is that you can use the sun to concentrate the solution and store the concentrate as long as you wish, effectively giving you cooling on demand.
  18. bryan1
    bryan1 Well-Known Member
    Aug 4, 2004
    1,679
    46
    Adelaide Hills Sth Oz
    Hiya Mike (Pommie),
    When you say 'we' do you mean your involved? As I'm very interested in developing my own RE based aircon but the first sticking point is to legally get Ammonia I need to get a licience first and be a registered business to be able to get it. The business part isn't a problem just the red tape is. Now is Br of CL readily available here in Oz and does the same rule apply?.
    Anyway I've talked on irc to 3 guys who made the solar ice maker and they all said it worked perfect and they average around 20-30 pounds of ice a day.
    Nigle's quote of 'it's just not viable' is a typical response from a city slicker who only needs to turn a knob on their aircon for cooling. For us R.E mob life aint that simple for example: my 3kw pure sinewave inverter with a 9kw surge wont start the aircon in my shed.
    Cheers Bryan ;)
    Our main fridge in our house is an absorbant ammonia one and even when it's 43C in the shade the fridge itself is still sitting on 2C. The only drawback is it's only a 290 litre fridge and that was the biggest available 4 years ago when we got it. I did a trial last year on it by turning off the gas pilot light and throwing a 100 watt globe in there and yes the fridge still worked :D . But the gas consumption is measly so I switched it back over.
  19. Pommie
    Mar 18, 2005
    10,022
    317
    Brisbane Australia
    Hi Bryan,
    I used the term 'we' as I was answering the previous posters question "why do we use amonia chloride solution ?"
    I am not involved but have had the intention to get involved for a few years, just never got around to it. As far as obtaining Br and Cl (both nasty substances), I think you will have a problem. The good news is you don't need them, you need Lithium Chloride or Lithium Bromide (both harmless powders). On a non industrial scale, Lithium Chloride can be made from Lithium Carbonate (Pottery supplier) and hydrochloric acid. For larger amounts a chemical supply company should be able to supply either with no restrictions. The main drawback is that both are lithium salts and are therefore corrosive.
  20. bryan1
    Aug 4, 2004
    1,679
    46
    Hi Mike,
    First thanks for the quick reply ;) and second thanks for the infomation on the lithum cloride :D . As far as a corrosive enviroment goes I'll be making my proto system out of S.S. anyway. Just means when I do decide to get to the making stage I won't be dandying about a the rental on a bottle of argon aint cheap and when you tig weld S.S you need to purge the line so I'll be in for a 'G' sized bottle when I do it.
    Cheers Bryan :D
  21. rjvh
    rjvh New Member
    Dec 20, 2007
    863
    6
    cambodia
    make sure your valves are also SS
    also your pipe should be thick enough to withstand pressures up to 12 bar (175 PSI)
Share This Page
