    Dismiss Notice
Solar & battery for desktop computer
Discussion in 'Renewable Energy' started by easytim, Mar 28, 2008.
  1. easytim
    easytim New Member
    Aug 31, 2006
    27
    0
    St. Louis , Missouri
    I'm wanting to build my own solar system that will keep a battery charged to to run a desktop,router and cable modem so I can operate 24/7 on its own. Can someone point me in the right direction where to get batteries, power invertor and solar panels. I'm willing to do what ever it takes. I like the DIY stuff.
    THANKS,
    easytim
  2. Torben
    Torben Well-Known Member
    Oct 6, 2006
    2,507
    34
    B.C., Canada
    Canadian Tire sells everything you need. Of course if you don't live in Canada that's useless information. If you filled in your location information in your profile you'd maybe get some more replies. Nobody likes to guess.
    Torben
  3. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,185
    644
    Ex Yorks' Hants UK
    Have you measured the current required for theses devices.?
    As Torben says, if we knew your location we could give more info.
    eg: if you live in England you will need big panels and batteries, not much sun these days, especially for 24/7 operation.:rolleyes:
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. easytim
    easytim New Member
    Aug 31, 2006
    27
    0
    I live in the Midwest
  6. ericgibbs
    Jan 4, 2007
    21,185
    644
    Ex Yorks' Hants UK
    I hope you get more Sun out there than we do...:D
    I would recommend that you measure the current drawn by each piece of equipment you are using. Let us know the values.
    This will give an indication of the size of the panels and the batteries required.
    You should also consider the losses in an dc to ac mains output invertor.
    Remember some of the equipment probably operates from an external dc psu or could be modified to work from a low voltage dc source, this will reduce the size of the invertor required.
    If it must be 24/7 for the full year, calculate the solar panels to suit the reduced sunshine during the winter months.
  7. easytim
    easytim New Member
    Aug 31, 2006
    27
    0
    total watts 252 watts being used
    O.K. cable modem, 8 port netgear hub, D-link wireless router, axis video sever, computer without LCD uses a total watts 252 watts.
  8. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
  9. easytim
    easytim New Member
    Aug 31, 2006
    27
    0
    yes, 252 watts at 120 volts
  10. ericgibbs
    Jan 4, 2007
    21,185
    644
    Ex Yorks' Hants UK
    Using 12V panels/batteries and just for explanation assuming 100% overall.
    Thats 252w/12v = 21Amps
    At a rough calculation for a 24hr worst case period thats a 24hr * 21A =504AHr battery.!
    Allowing for a invertor conversion efficiency of say, 75% gives 504/0.75 =672AHr Battery.
    Allowing for a battery recharge efficiency of 60% at a charge rate 21Amps,
    just to keep the batteries topped up, 21/0.6 = 36Amps
    Allowing for 12hrs of sunshine per day,,, 36A * 2 =72A
    Although these calculations are very rough, it would suggest to me that the project is going to be VERY expensive.
    You have explained that you need to keep the system running 24/7, can I ask why.?
  11. mvs sarma
    mvs sarma Well-Known Member
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    The attempt of Easytim is really appreciable. I have few suggestions for Easytim.
    While on one side the trial for Solar based power kit can be continued, He/she can perhaps support it by thinking around power conservation--
    1. Attempt to convert the PC to a Laptop where the power demand falls,
    2. Look around for possibility of direct feeding of Dc power to other devices where ever applicable, in order to help reduce conversion losses from Dc to 120V and back to Dc. It will be one time investment and later on help reduce power demand on the solar based power unit.
    3. Generally such power plants are designed around a triangular system. like solar, diesel Genset, and public mains. As pointed by other members, during cloudy days etc the genset and public main will support the system.
  12. easytim
    easytim New Member
    Aug 31, 2006
    27
    0
    Thanks for the help, I need to look at all my devices and see how many are powered by 12vdc. And also think about docking a laptop to use as a desktop.
    What part of India are you at? mvs sarma
  13. easytim
    easytim New Member
    Aug 31, 2006
    27
    0
    Thanks for the help, I need to rethink somethings, 24/7 I think is the best way to run a computer, just for that reason alone. It may not be the best way with solar
  14. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    Thanks for indicating need to modify Location data. I have now given a general mod.
    I live at Hyderabad (17°21′58″N : 78°28′34″E), Andhra Pradesh, India.
  15. HS3
    HS3 New Member
    Apr 6, 2008
    42
    1
    Running a standard desktop would be wasteful because of the many conversions involved: solar to DC battery to inverter AC to PSU and back to low voltage. Every conversion wastes energy. The best way is to use a laptop which will be fed at about 18 V so you can use a car-air adapter from a 12V battery. This is more efficient and laptops tend to use much less energy to begin with so you will need to generate much less energy in the first place.
    I suppose you could find desktop PSU which starts out from 12 VDC but that is rare and will not be cheap.
  16. The Mad Professor
    The Mad Professor New Member
    Mar 5, 2006
    315
    2
    Newent England
    Low power computing is possibble.
    Wander over to http://linitx.com/ for some inspiration
    they specialise in small form factor computers for automotive use
    low power motherboards and PSU's designed for a 12vDC input.
    Price wise.. the motherboards are not dirt cheap but you do get bang 4 your buck performance..
    Changing over to a Linux operating system such as "Puppy"
    also has power saving benefits. I use it on a bootable re-writeable DVD and don't need a hard drive to run, will also operate from a USB flash drive if motherboard supports this as a boot option.
    Calculate how much power the HDD alone requires, it may surpise you.
    Students of recent history may also recall Win98 from microsoft..
    a little heavier than Puppy linux (Puppy is 90Mb / Win98 is around 240Mb)
    Well Win98 will install to a USB flash drive and run quite happily even though a tad slower than Puppy Linux. The point is why have the hard drive spinning and using power if it's not actually doing anything?
    Puppy by the way is a free download, and Win98.. well there are lots of old copies & product keys about.
  17. Thunderchild
    Thunderchild New Member
    Jul 3, 2005
    2,294
    9
    UK
    erm pray your not from that crack pot cult are you ? that beleive its beeter for a pc to run 24/7 rather than only when needed pray whats the exscuse this time ? apart from being too lazy to press a button ?, no don't tell us that it damages the processor to turn it on and off or anything else because thats utter lazy ********
  18. HarveyH42
    HarveyH42 Banned
    Feb 25, 2006
    3,442
    18
    Not Here
    I tend to leave my PC running while I'm home, and likely to be using it on and off through out the day. Always kind of wondered about whether frequent rebooting was rough on it. Mostly I don't like the long time it takes, but the various noises it goes through as everything is spinning up, kind of sounds like a struggle. Envision the power supply being stressed, as every fan, motor, and circuit suddenly draws max. current all at once, before settling down to normal operation. Suppose it depends on how well the computer is built.
  19. Thunderchild
    Jul 3, 2005
    2,294
    9
    UK
    erm boloks I've never had something fail on me due to stress like you sugest the stuff is made to be turned on and off and its going to be stressing it at least as much to run it non stop as it is to turn it off, sure it makes a bit of bnoise didn't you know that motors and fans make noise ? the most of the noise made by the HDD is the armature swinging into position something it will possibly do constantly whilst on anyhow the acutal dish spinning you hardly hear, most of the running noise is air flow. stressful noise ? I have 3 HDDs and starting my computer don't sound bad at all things turn on they will make some noise unless they are solid state. the only HDD I've had fail was very well used and i had plenty of warning to get my stuff off of it. also when you leave it all on the HDD powrrs down anyhow so what did you gain ?
    stop making so called technical exscuses for being lazy !
Share This Page
