software filtering
waqar
i have made the pulse dialing code to some extend and need advice your all of you...
Objective:-
Detecting Signal Digit Dialing.considering only one telephone.
If digit "2" is pressed disconnect dial tone from the the telephone set otherwise keep connecting the dial tone.
; CHECKING ONE TELEPHONE LINE WITH MT8816 AND AT89C52
; P2.0 FOR DETECTING OFF HOOK (1) AND ON HOOK (0)
; Dial Tone Y0 OF MT8816 and telephone via slic is connected with X2
; ADDRESS LINE + DATA PIN OF MT8816 WITH P1 (date pin p1.7)
; Strobe = p3.7
; crsytal 11.05KOH
ORG 00H
LJMP MAIN
ORG 0030H
MAIN:
MOV P0,#00000000B ;port IS CLEARED
MOV P3,#00000000B ;StROBE IS CLEARED
MOV P2,#00000000B ;RESETING THE PIN
MOV P1,#00000000B ;RESETING THE PIN
OFF:
JNB P2.0,OFF ;WAITING FOR OFF-HOOK
CALL DELAY_10MS ;for debouncing, filtering codition
MOV P1,#10010000B ;x2-y0 DIAL TONE connection
SETB P3.7 ;STROBE IS SET HIGH
ON:
JB P2.0,ON ;waiting for digit dial
MOV R6,#00D ;pulse counting regsiter
J:
CALL DELAY_60MS ; pulse low time
INC R6 ;calculate no. of zeros
CALL DELAY_40MS ;pulse high time
CALL DELAY_10MS ;software filtering
JNB P2.0,J ;checking for more than 1 pulse
JB P2.0,CHECK3 ;check if all pulses came
CHECK3:
CJNE R6,#02D,DO ;dialed digit is 2 then remove dial tone
CLR P1.7
CLR P3.7
DO:
JNB P2.0,MAIN ;waiting on hook
SJMP DO
DELAY_60MS:
MOV R0,#05D
L2: MOV R1,#53D
L1: MOV R2,#250D
DJNZ R2,$
DJNZ R1,L1
DJNZ R0,L2
RET
DELAY_40MS:
MOV R0,#05D
A2: MOV R1,#49D
A1: MOV R2,#180D
DJNZ R2,$
DJNZ R1,A1
DJNZ R0,A2
RET
DELAY_10MS:
MOV R0,#05D
C2: MOV R1,#10D
C1: MOV R2,#200D
DJNZ R2,$
DJNZ R1,C1
DJNZ R0,C2
RET
END
Now i have used the above program firstly to see if low comes one dialing a digit it worked...but when iam using it to count the more than one pulse its not working...please advice some thing about the above.
Also since maximum time for receiving the pulses will 1 second which will be needed when digit "0" is pressed. I have tried to make a counter which multiply 40 milli seconds with 30 = 1200 micro-seconds
which checks after each decrement whether another pulse has arrived or not but it also did not worked...
actually the pulse counting register is counting more than one pulse..
