    Dismiss Notice
SL100 transistor equivalent
Discussion in 'Datasheets, Manuals or Parts' started by Uberethair, Jan 23, 2010.
  1. Uberethair
    Uberethair New Member
    Jan 23, 2010
    3
    0
  2. yafch
    yafch New Member
    Nov 28, 2008
    87
    0
  3. Uberethair
    Jan 23, 2010
    3
    0
    Right, thanks, could you give me an example of a general purpose NPN transistor, would a BC 108 do?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. yafch
    yafch New Member
    Nov 28, 2008
    87
    0
    OK. the circuit works on 9v supply. So with a such voltage operation BC108 can be used.
    There are thousands of general purpose transistors out there. Few of them are like. 2N2222A. 2N3053. 2N2907. BC327. BC337.BC546. BC547.BC548 ..........................are low power transistors.
    For higher power transistors like, 2N3055. TiP31C. TiP32C.Tip35C.Tip36C..............
    For higher voltage and low power MPSA12.MPSA42,MPSA92........................
    And so on so on so on.
    There are hundreds of thousands of transistors out there.
    Only you need to do is check there datasheet for there parameters.
    I have datasheets for about 1000 transistor and same number of IC,s and a lot of other components in my computer.
  6. Uberethair
    Jan 23, 2010
    3
    0
    So that's sorted I can use the BC 108 instead of the SL100, thanks a lot.
  7. saleem sagar
    saleem sagar New Member
    Oct 16, 2016
    1
    0
    Lahore
    I find sl100 comparison npn transistor bc548b working equal to SL 100 transistor....
  8. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,049
    541
    AZ 86334
    Hi Saleem,
    welcome to the forum. Notice that the thread you replied to is 6 years old, so likely that the original Thread Starter (TS) got his question answered then, and may not be listening anymore..., especially that the TS has only posted three times...
  9. spec
    spec Well-Known Member Most Helpful Member
    Oct 27, 2015
    5,828
    709
    Somerset UK GMT
    Just a few points for the record. The SL100 is an obsolete low power, high conductance transistor, rather than a small signal, high hFE (current gain) low noise transistor. The SL100 is also in a metal can, so probably has a lower thermal resistance junction/ambient than plastic case types.
    The SL100 important parameters are:
    VCEo max = 50V
    IC max = 500mA
    Pd max: 800mW
    VCE sat max @150mA: 600mV
    J temp max: 200 deg C (probably a misprint and should be DegCW)
    thr J/amb: not stated
    http://www.engineersgarage.com/sites/default/files/SL100_0.pdf
    The PN2222A parameters are:
    VCEo max = 40V (worse)
    IC max = 1A (much better)
    Pd max: 625mW (worse)
    VCE sat max @150mA: 300mV (much better)
    J temp max: 150 Deg C
    thr J/amb: 200 Deg CW
    https://www.fairchildsemi.com/datasheets/PN/PN2222A.pdf
    The BC337 parameters are:
    VCEo max = 45V (worse)
    IC max = 800mA (better)
    VCE sat max @500mA: 700mV (much better)
    http://www.onsemi.com/pub_link/Collateral/BC337-D.PDF
    As the impedance of the buzzer is unknown it is not possible to say whether a lesser transitor will be OK. But the slightly lesser VCEo of the PN2222 and BC337 will not be a problem for this application.
    Metal can transistors normally have a lower thr J/ amb, so the PN2222 and BC337 possibly have a higher thermal resistance but this should not be a problem, in practice. The much lower VCE sat will more than compensate for this anyway. This also applies to an extent to PD.
    The BC10x family of transistors have a maximum current of only 100mA and are not recommended. The BC54x are modern replacements for the BC10x family. The BC84x family are surface mount versions.
    The 2N2907 and BC327 are PNP transistors.
    End of lecture.:)
    spec
Share This Page
