I'm making a remote control for my outside lights. The only thing not designed is the antennas - everything else has been designed and tested. I've just been using short pieces of wires for antennas and the range seems to be pretty good, amazingly.Roboticinfo said:What are you trying todo?
I mean what type of project are you doing?
Roboticinfo said:Any antenna should work fine but I would recommend a antenna off of a cordless phone like a 900mhz
depending were you bought your tx/rx
it could go as far as 500 feet.
The datasheet gave no information on this whatsoever. I think they said that a quarter wave antenna would be a good idea - but they gave no dimensions or anything like that.Nigel Goodwin said:As already suggested, a 1/4 wave whip is only short, and VERY easy to calculate - but even easier, read the datasheet for the RF modules you use, they generally give one or two exact aerial dimensions - particularly as the aerial is an important part of the licence free conditions!.
awesome - I'll start it out with that as it's by far the simplest solution. Thanks!chiba said:> Could a specific length of wire work?
Yep, Just make your wire the right length and it should work pretty good.
I specificly said in the post that they were $2.00.Roboticinfo said:Didn't those antennas cost $10.00?
Anyway for stylish antennas
Roboticinfo said:But you would need two feet of wire!
A quarter wave (6.5") wouldn't work? Actually for the receiver 2 feet isn't a problem at all - but for the transmitter it would be.Roboticinfo said:But you would need two feet of wire!
