serial communication with pic 18f4550
neelam29
dear all,
m trying to make a project on interfacing rs232 with pic18f4550. m new to rs232 .cananybody please help me with some examples based on rs232 communication with pic18f.
neelam29 said:
I'm trying to make a project on interfacing rs232 with pic18f4550. I'm new to rs232. Can anybody please help me with some examples based on rs232 communication with pic18f.
Here's some code I wrote when I was learning to do RS232 on the 18F1320. It's just simple polled RS232. I have some 4550 code, but I don't know if it works. This 1320 code definitely does.
	list	p=18F1320
	include	<p18f1320.inc>
	CONFIG	OSC=INTIO2,WDT=OFF,MCLRE=ON,LVP=OFF,DEBUG=ON
	cblock	0x00
		d1,d2,d3,dec1,dec2,count,num
	endc
	org	0x0000
init	bsf	OSCCON,IRCF2	;set to 8MHz clock
	bsf	OSCCON,IRCF1
	bsf	OSCCON,IRCF0
	movlw	0x7f		;set PortA to all digital
	movwf	ADCON1
	clrf	TRISA		;set PortA pins to output
	clrf	LATA		;turn off LEDs
	clrf	count
	movlw	b'00010010'	;set PortB - RB4=RX=input
	movwf	TRISB
	call	rs_init
	bsf	TXSTA,TXEN	;transmit enable
main	clrf	TBLPTRH
	movlw	text
	movwf	TBLPTRL
next_ch	tblrd	*+
	movf	TABLAT,W
	bz	goagain
	call	rs_send
	goto	next_ch
goagain	incf	num
	movf	num,W
	call	fix
	movf	dec1,W
	call	rs_send
	movf	dec2,W
	call	rs_send
	movlw	0x0d
	call	rs_send
	movlw	0x0a
	call	rs_send
	call	delay
	call	delay
	call	delay
	call	delay
	goto	main
;Sends byte in W to RS232
rs_send	movwf	TXREG
sdloop	btfss	TXSTA,TRMT
	goto	sdloop
	return
text	db	"RS232 on the 8 MHz clocked PIC 18F1320!",0x0d,0x0a,"It is the
greatest!",0x0d,0x0a,0x0a
rs_init	movlw	0x0c		;set for 9600 baud @ 8MHz clock
	movwf	SPBRG
	bcf	TXSTA,BRGH	;clear Baud Rate Select Bit (low speed)
	bcf	BAUDCTL,BRG16	;select 8-bit baud rate generator
	bcf	TXSTA,SYNC	;asynchronous mode
	bsf	RCSTA,SPEN	;enable serial port
	return
;*fix - subroutine takes byte passed in W - splits it into
;*two ascii bytes in dec1 and dec2, representing decimal digits.
fix	movwf	dec2		;put number in dec2
	clrf	count		;count = 0
	movlw	10		;W = 10
tens	subwf	dec2,F		;subtract 10 from number
	btfsc	STATUS,C	;check if result <10
	goto	again		;no, go again
	movf	count,W		;yes, put count in W
	addlw	0x30		;add $30 to make it an ASCII number
	movwf	dec1		;and store it in dec1
	movf	dec2,W		;get remainder (2nd digit)
	addlw	10		;put the last subtract back
	addlw	0x30		;add $30 to make it ASCII
	movwf	dec2		;store it back in dec2
	return			;and return
again	incf	count,F		;increment count
	goto	tens		;go again
delay	movlw	0x01
	movwf	d1
	movlw	0x7f
	movwf	d2
	movlw	0x01
	movwf	d3
delay_0	decfsz	d1,f
	goto	$+6
	decfsz	d2,f
	goto	$+6
	decfsz	d3,f
	goto	delay_0
	return
	end
Dear frnds
this code i tried out for usart with pic18f4550 but m geeting the error which i have decribed below ..please help out.m using mplabc18 compiler
#include <p18f4550.h>
#include <usart.h>
void rx_handler (void);
#define BUF_SIZE 25
#pragma idata bigdata
char data[11][BUF_SIZE+1] = {
{ "String #0\n\r" },
{ "String #1\n\r" },
{ "String #2\n\r" },
{ "String #3\n\r" },
{ "String #4\n\r" },
{ "String #5\n\r" },
{ "String #6\n\r" },
{ "String #7\n\r" },
{ "String #8\n\r" },
{ "String #9\n\r" },
{ "Invalid key (0-9 only)\n\r" }
#pragma idata
#pragma code rx_interrupt = 0x8
void rx_int (void)
_asm goto rx_handler _endasm
#pragma code
#pragma interrupt rx_handler
unsigned char c;
/* Get the character received from the USART */
c = ReadUSART();
if (c >= '0' && c <= '9')
c -= '0'; /* Display value received on LEDs */
PORTB = c;
putsUSART (data[c]);
else
putsUSART (data[10]); /* Display value received on LEDs */
PORTB = c;
/* Clear the interrupt flag */
PIR1bits.RCIF = 0;
void main (void)
/* Configure all PORTB pins for output */
TRISB = 0;
OpenUSART (USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH, 103);
putrsUSART (
(const far rom char *)"\n\rEnter a digit 0-9!\n\r");
RCONbits.IPEN = 1;
IPR1bits.RCIP = 1;
INTCONbits.GIEH = 1;
while (1)
the linker file added is
// File: 18f4550.lkr
// Sample linker script for the PIC18F4550 processor
LIBPATH .
FILES c018i.o
FILES clib.lib
FILES p18f4550.lib
CODEPAGE NAME=vectors START=0x0 END=0x29 PROTECTED
CODEPAGE NAME=page START=0x2A END=0x7FFF
CODEPAGE NAME=idlocs START=0x200000 END=0x200007 PROTECTED
CODEPAGE NAME=config START=0x300000 END=0x30000D PROTECTED
CODEPAGE NAME=devid START=0x3FFFFE END=0x3FFFFF PROTECTED
CODEPAGE NAME=eedata START=0xF00000 END=0xF000FF PROTECTED
ACCESSBANK NAME=accessram START=0x0 END=0x5F
DATABANK NAME=gpr0 START=0x60 END=0xFF
DATABANK NAME=gpr1 START=0x100 END=0x1FF
DATABANK NAME=gpr2 START=0x200 END=0x2FF
DATABANK NAME=gpr3 START=0x300 END=0x3FF
DATABANK NAME=usb4 START=0x400 END=0x4FF PROTECTED
DATABANK NAME=usb5 START=0x500 END=0x5FF PROTECTED
DATABANK NAME=usb6 START=0x600 END=0x6FF PROTECTED
DATABANK NAME=usb7 START=0x700 END=0x7FF PROTECTED
ACCESSBANK NAME=accesssfr START=0xF60 END=0xFFF PROTECTED
SECTION NAME=CONFIG ROM=config
STACK SIZE=0x100 RAM=gpr3
error which m getting while complilation is
Error - section 'bigdata' can not fit the section. Section 'bigdata' length=0x0000011e
Errors : 1
Getting back to basics, if you need to hook the 4550 up to a PC make sure you are using a level shifter such as a MAX232 or similar.
serial interfacing of computer with PIC 18F452
i m doing my project... n facing the problem
that how to send data from serial port of computer to PIC 18F452 microcontroller with the help of MAX232, and rs232 connector... plz help me and send its schematic diagram and assembly code for interfacing computer and pic micro controller. thnx
Errors : 1
The reason is because ur variable is too large to fit in the allocated memory..
You can solve it by breaking down 'bigdata' into smaller chunks eg 'bigdata1', 'bigdata2' etc and store them in different banks by using
#pragma udata bigdata1
#pragma udata bigdata2
For more info, you can go to the link below..
Microchip Technology User Forums
HTH
