segment clock
lacikes
Hi, I have to create clock on a segment display that will shows seconds, minutes and hours. Something like this picture **broken link removed**. Please can somebody help mi with this. Thank you.
Not enough info.
Is this a school or college assignment?
How accurate does it need to be (perhaps not very, if this is just a proof-of-concept project)?
Presumably you need some means of setting the time?
Is it to be mains or battery powered?
Do you need an alarm function?
Are there any size constraints?
Yes it is a college assignment. All I can say about this is that we are programming in AVR studio 5 and and whole layout of this assignment is:
for 1 point - Create a function that will have value as an input data type unsigned char. The return value of this function will also be unsigned char. This function returns a value that represents a entered number displayed on the segment display. Demonstrate the correct functioning of the program.
Chat unsigned BCD (unsigned char input) {
if (input == 8) return 0xff; / / example for number 8
for 3 points - Display two-digit number on the display. That is a number between 10 and 99
for 5 points - Create a counter that will increment the value on the display every 1 sec from 0 to a value of 99th
for 7 points - Create a clock that will display the seconds, minutes and hours.
I'm not familiar with the AVR Studio 5 IDE. Are you supposed to be using it merely to run a simulated clock? Is this just a software exercise? Or are you developing the software and then going on to produce an actual clock?
I've programmed a DCF 77 Stop Clock with additional Functions:
This program was produced by the
CodeWizardAVR V1.25.5 Standard
Automatic Program Generator
© Copyright 1998-2007 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project : DCF77_Stoppuhr
Version : 1.2
Date    : 06.01.2009
Author  : Wilhelm Krug
Company : 92345 Dietfurt, Germany
Comments:
Chip type           : ATmega16L
Program type        : Application
Clock frequency     : 8,000000 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
#include <mega16.h>
#include <delay.h>
#include <stdlib.h>
#include <string.h>
// Zeichentabelle für 7 Segment Display
//0,1,2,3,4,5,6,7,8,9,A,b,c,d,E,F,h,J,L,n,o,P,r,u,[]
volatile unsigned char uc_chartable[25]={
0b00111111,/*0*/
0b00001100,
0b01011011,
0b01011110,
0b01101100,
0b01110110,
0b01110111,
0b00011100,
0b01111111,
0b01111110,/*9*/
0b01111101,/*A*/
0b01100111,/*b*/
0b01000011,/*c*/
0b01001111,/*d*/
0b01110011,/*E*/
0b01110001,/*F*/
0b01101101,/*H*/
0b00011110,/*J*/
0b00100011,/*L*/
0b01000101,/*n*/
0b01000111,/*o*/
0b01111001,/*p*/
0b01000001,/*r*/
0b00000111,/*u*/
0b00000000};/*Leerzeichen*/
// Segmentbuffer
volatile unsigned char uc_segment[6]={0,0,0,0,0,0};
volatile unsigned char uc_segmentcounter=0;
// Displaysteuerung
volatile unsigned char uc_dispmode=0;
// Stoppuhr Zähler Steuerung
bit ub_counting=0;                     /* Flag Stoppuhr läuft */
bit ub_stopdelay=0;                     /* Flag Stopauslöseverzögerung aktiv */
bit ub_autoreset=0;                     /* Flag Autoreset der Stoppuhr aktiv */
volatile unsigned int ui_stopdelay;     /* Wert für das Stopdelay */
volatile unsigned int ui_stopcounter=0; /* Counter für das Stopdelay */
eeprom unsigned int ee_stopdelay=600;   /* EEPROM SPeicherplatz für das Stopdelay */
volatile unsigned int ui_autoresetcount=0; /* Downcounter für den Autoreset */
volatile unsigned int ui_autoreset;     /* Wert für den Autoreset */
eeprom unsigned int ee_autoreset=500;   /* EEPROM Speicherplatz für den Autoreset */
// Stoppuhr UP Zähler
volatile unsigned char uc_countmsek=0;
volatile unsigned char uc_countsek=0;
volatile unsigned char uc_countmin=0;
volatile unsigned char uc_countstd=0;
// Stoppuhr Down Zähler
volatile unsigned char uc_downmsek=0;
volatile unsigned char uc_downsek=0;
volatile unsigned char uc_downmin=0;
volatile unsigned char uc_downstd=0;
eeprom unsigned char ee_downmsek=0;
eeprom unsigned char ee_downsek=0;
eeprom unsigned char ee_downmin=1;
eeprom unsigned char ee_downstd=1;
// DCF Uhr
unsigned int MS_Count = 0,old_ms_count = 0,MeasureBit = 0;
volatile unsigned char cnt_okay = 0;
volatile char sek_count = 0;
volatile unsigned char TimeHours = 0, TimeMinutes = 0, TimeSeconds = 0, DateMonth = 0, DateDay = 0,Weekday = 0;
volatile unsigned int  HiLoTimeAverage = 10;
volatile unsigned int  TimeMilliseconds = 0;
volatile unsigned char DCF77Bit = 0,NewBit = 0;
volatile unsigned char value = 0;
volatile char startbit,parity;
volatile unsigned char dcf77_hour = 88, dcf77_minute = 88, dcf77_day = 88, dcf77_month = 88, dcf77_wday  = 88, dcf77_year  = 88;
// Tastaturabfrage zum Setup
volatile unsigned char uc_readtast=0;
volatile unsigned char uc_oldtast=0;
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART Transmitter buffer
#define TX_BUFFER_SIZE 40
char tx_buffer[TX_BUFFER_SIZE];
#if TX_BUFFER_SIZE<256
unsigned char tx_wr_index,tx_rd_index,tx_counter;
#else
unsigned int tx_wr_index,tx_rd_index,tx_counter;
#endif
// USART Transmitter interrupt service routine
interrupt [USART_TXC] void usart_tx_isr(void)
if (tx_counter)
   --tx_counter;
   UDR=tx_buffer[tx_rd_index];
   if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
#ifndef _DEBUG_TERMINAL_IO_
// Write a character to the USART Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter == TX_BUFFER_SIZE);
#asm("cli")
if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0))
   tx_buffer[tx_wr_index]=c;
   if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
   ++tx_counter;
else
   UDR=c;
#asm("sei")
#pragma used-
#endif
// External Interrupt 0 service routine -> Starten der Stoppuhr
interrupt [EXT_INT0] void ext_int0_isr(void)
ub_counting=1;
GICR&=0b00111111;
GIFR|=0b11000000;
ui_stopcounter=0;
ub_stopdelay=1;
// External Interrupt 1 service routine -> Stoppen der Stopuhr
interrupt [EXT_INT1] void ext_int1_isr(void)
unsigned char uc_i,uc_stringlengh;
unsigned char uc_stringbuffer[4];
unsigned char uc_sendstring [40];
ub_counting=0;
ui_stopcounter=0;
GICR&=0b00111111;
// Aktivierung des Autoreset bei Resetzeiten größer 1 Sekunde
if(ui_autoreset>99)
    ui_autoresetcount=ui_autoreset+100;
    ub_autoreset=1;
It's written with CodeVision AVR in "C".
The Clock never must be seted, that will be done by an DCF 77 Receiver Module, that gives out the Time Information with Pulses.
That works well in whole mid Europe.
When you have no Time normal Radio Transmitter availible, you can use GPS as Time Source. You has only to programm the entire GMT difference ( +/- hrs ).
The Clock runs forward and backward. A stop Clock forward and Backward is integrated. The stop time will be giveb out via RS232 for a terminal Program or a simple Printer.
An EAGLE Schematic and Layout is availible.
Second Part of Programm:
// Nur bei Stoppuhr Betrieb übertragung per seriell zum PC
if(uc_dispmode==0)
    itoa(uc_countstd,uc_stringbuffer);
    if(uc_countstd<10)
        strcpyf(uc_sendstring,"0");
        strcat(uc_sendstring,uc_stringbuffer);
    else
        strcpy(uc_sendstring,uc_stringbuffer);
    strcatf(uc_sendstring,";");
    itoa(uc_countmin,uc_stringbuffer);
    if(uc_countmin<10){strcatf(uc_sendstring,"0");};
    itoa(uc_countsek,uc_stringbuffer);
    if(uc_countsek<10){strcatf(uc_sendstring,"0");};
    itoa(uc_countmsek,uc_stringbuffer);
    if(uc_countmsek<10){strcatf(uc_sendstring,"0");};
    // Steuerzeichen anfügen
    uc_stringlengh=strlen(uc_sendstring);
    uc_sendstring[uc_stringlengh]=13;    /* Carriage Return 13*/
    uc_sendstring[uc_stringlengh+1]=10;    /* Line Feed 10 */
    uc_sendstring[uc_stringlengh+2]=0;     /* Stringende anfügen */
    for(uc_i=0;uc_i<uc_stringlengh;uc_i++)
        putchar(uc_sendstring[uc_i]);
// Nur bei Stoppuhr Countdown betrieb übertragung per seriell zum PC
if(uc_dispmode==1)
    itoa(uc_downstd,uc_stringbuffer);
    if(uc_downstd<10)
    else
    itoa(uc_downmin,uc_stringbuffer);
    if(uc_downmin<10){strcatf(uc_sendstring,"0");};
    itoa(uc_downsek,uc_stringbuffer);
    if(uc_downsek<10){strcatf(uc_sendstring,"0");};
    itoa(uc_downmsek,uc_stringbuffer);
    if(uc_downmsek<10){strcatf(uc_sendstring,"0");};
// External Interrupt 2 service routine DCF Bit Auswertung
interrupt [EXT_INT2] void ext_int2_isr(void)
 if((MCUCSR&0b01000000)>0)
    MCUCSR&=0b10111111;
    MeasureBit=MS_Count-old_ms_count;  // Pausenzeitmessung
    old_ms_count=MS_Count;
    if(MeasureBit > 160)         // Rücksetzen der Sekunden auf 0
        TimeMilliseconds=0;
        sek_count = 0;
 else
    MCUCSR|=0b01000000;
    MeasureBit = MS_Count - old_ms_count; // Impulszeitmessung
    if(MeasureBit < 50)
         if(MeasureBit > HiLoTimeAverage + 3) DCF77Bit = 1;
         else DCF77Bit = 0;
// Timer 0 overflow interrupt service routine Segment Multiplexing
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
#asm("SEI");      /* Interrupts für Stoppuhr freigeben !*/
switch (uc_segmentcounter)
    case 0:
    PORTC=0;
    PORTA.5=0;
    delay_us(20);
    PORTA.0=1;
    PORTC=uc_segment[uc_segmentcounter];
    if(PINB.2>0)
        PORTC.7=1;
    break;
    case 1:
    PORTC=0;
    PORTA.0=0;
    delay_us(20);
    PORTA.1=1;
    break;
    case 2:
    PORTC=0;
    PORTA.1=0;
    delay_us(20);
    PORTA.2=1;
    break;
    case 3:
    PORTC=0;
    PORTA.2=0;
    delay_us(20);
    PORTA.3=1;
    break;
    case 4:
    PORTC=0;
    PORTA.3=0;
    delay_us(20);
    PORTA.4=1;
    break;
    case 5:
    PORTC=0;
    PORTA.4=0;
    delay_us(20);
    PORTA.5=1;
    break;
uc_segmentcounter++;
if(uc_segmentcounter>5){uc_segmentcounter=0;};
// Timer 1 output compare A interrupt service routine Clock Function
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
// Stopdelay aktiviert ?
if(ub_stopdelay>0)
    ui_stopcounter++;
// Autoreset aktiv ?
if(ub_autoreset>0&&ui_autoresetcount>0)
    ui_autoresetcount--;
    if((ui_autoresetcount+1)==0){ui_autoresetcount=0;};
// Stoppuhr
if(ub_counting>0)
    uc_countmsek++;
    if (uc_countmsek>99)
        uc_countmsek=0;
        uc_countsek++;
        if (uc_countsek>59)
            uc_countsek=0;
            uc_countmin++;
            if(uc_countmin>59)
                uc_countmin=0;
                uc_countstd++;
                if(uc_countstd>99)
                    uc_countstd=0;
// Countdown
    if(uc_downmsek==0&&uc_downsek==0&&uc_downmin==0&&uc_downstd==0)
        if(ui_autoreset>99&&ub_autoreset==0&&uc_dispmode==1)
            ub_autoreset=1;
    else
        uc_downmsek--;
        if(uc_downmsek+1==0)
            uc_downmsek=99;
            uc_downsek--;
            if(uc_downsek+1==0)
                uc_downsek=59;
                uc_downmin--;
                if(uc_downmin+1==0)
                    uc_downmin=59;
                    uc_downstd--;
// static char startbit,parity;
 MS_Count++;
 TimeMilliseconds++;
 if(TimeMilliseconds > 99) // one second
   NewBit = 1;
   if(++TimeSeconds >59)
     TimeSeconds = 0;
     if(++TimeMinutes > 59)
        TimeMinutes = 0;
        if(++TimeHours > 23)
         TimeHours = 0;
  switch (sek_count++)
            case 20: /* startbit */
                startbit = DCF77Bit;
                if(startbit)  cnt_okay++;
                break;
            /* decode numbers */
            case 21: /* minute */
            case 29: /* hour */
            case 36: /* day */
                parity  = value = DCF77Bit;
                break;
            case 22: /* minute */
            case 30: /* hour */
            case 37: /* day */
            case 43: /* weekday */
            case 46: /* month */
            case 51: /* year */
                parity ^= DCF77Bit;
                value += (DCF77Bit << 1);
                break;
            case 23: /* minute */
            case 31: /* hour */
            case 38: /* day */
            case 44: /* weekday */
            case 47: /* month */
            case 52: /* year */
                parity ^= DCF77Bit;
                value += (DCF77Bit<<2);
                break;
            case 24: /* minute */
            case 32: /* hour */
            case 39: /* day */
            case 48: /* month */
            case 53: /* year */
                parity ^= DCF77Bit;
                value += (DCF77Bit << 3);
                break;
            case 25: /* minute */
            case 33: /* hour */
            case 40: /* day */
            case 49: /* month */
            case 54: /* year */
                parity ^= DCF77Bit;
                if(DCF77Bit == 1) value += 10;
                break;
            case 26: /* minute */
            case 34: /* hour */
            case 41: /* day */
            case 55: /* year */
                parity ^= DCF77Bit;
                if(DCF77Bit == 1) value += 20;
                break;
            case 27: /* minute */
            case 56: /* year */
                parity ^= DCF77Bit;
                if(DCF77Bit) value += 40;
                break;
            case 57: /* year */
                parity ^= DCF77Bit;
                if(DCF77Bit) value += 80;
                break;
            case 28: /* minute */
                if(DCF77Bit == parity)
                   dcf77_minute = value;
                   cnt_okay++;
                   else dcf77_minute = 99;
                break;
            case 35: /* hour */
                   dcf77_hour = value;
                   cnt_okay++;
                   else dcf77_hour = 99;
                break;
            case 42: /* weekday */
                dcf77_day = value;
                parity ^= DCF77Bit;
                value = DCF77Bit;
                break;
            case 45: /* month */
                dcf77_wday = value;
                parity ^= DCF77Bit;
                value = DCF77Bit;
                break;
            case 50: /* year */
                dcf77_month = value;
                parity ^= DCF77Bit;
                value = DCF77Bit;
                break;
            case 59:
                 sek_count = 0;
                 break;
            case 58: /* Take all values  */
                 dcf77_year = value;
                if(DCF77Bit == parity) cnt_okay++;
                startbit = 0;
                break;
            case 1: /* Take all values  */
                 if(cnt_okay == 4)
                    TimeHours   = dcf77_hour;
                    TimeMinutes = dcf77_minute;
                    DateMonth   = dcf77_month;
                    DateDay     = dcf77_day;
                    TimeSeconds = 1;
                 cnt_okay = 0;
                 break;
void show_display(void)
unsigned char uc_buffer,uc_buffer1;
switch (uc_dispmode)
    case 0:
    if(uc_countstd>0)
        uc_segment[0]=uc_chartable[(uc_countsek%10)];
        uc_segment[1]=uc_chartable[(uc_countsek/10)];
        uc_segment[2]=uc_chartable[(uc_countmin%10)];
        uc_segment[3]=uc_chartable[(uc_countmin/10)];
        uc_buffer=uc_chartable[(uc_countstd%10)];
        uc_buffer|=0b10000000;
        uc_segment[4]=uc_buffer;
        uc_segment[5]=uc_chartable[(uc_countstd/10)];
    else
        uc_segment[0]=uc_chartable[(uc_countmsek%10)];
        uc_segment[1]=uc_chartable[(uc_countmsek/10)];
        uc_segment[2]=uc_chartable[(uc_countsek%10)];
        uc_segment[3]=uc_chartable[(uc_countsek/10)];
        uc_segment[4]=uc_chartable[(uc_countmin%10)];
        uc_segment[5]=uc_chartable[(uc_countmin/10)];
    break;
    case 1:
    if(uc_downstd>0)
        uc_segment[0]=uc_chartable[(uc_downsek%10)];
        uc_segment[1]=uc_chartable[(uc_downsek/10)];
        uc_segment[2]=uc_chartable[(uc_downmin%10)];
        uc_segment[3]=uc_chartable[(uc_downmin/10)];
        uc_buffer=uc_chartable[(uc_downstd%10)];
        uc_segment[5]=uc_chartable[(uc_downstd/10)];
    else
        uc_segment[0]=uc_chartable[(uc_downmsek%10)];
        uc_segment[1]=uc_chartable[(uc_downmsek/10)];
        uc_segment[2]=uc_chartable[(uc_downsek%10)];
        uc_segment[3]=uc_chartable[(uc_downsek/10)];
        uc_segment[4]=uc_chartable[(uc_downmin%10)];
        uc_segment[5]=uc_chartable[(uc_downmin/10)];
    break;
    // DCF 77 Funktion
    case 2:
        uc_segment[0]=uc_chartable[(TimeSeconds%10)];
        uc_segment[1]=uc_chartable[(TimeSeconds/10)];
        uc_segment[2]=uc_chartable[(TimeMinutes%10)];
        uc_segment[3]=uc_chartable[(TimeMinutes/10)];
        uc_buffer=uc_chartable[(TimeHours%10)];
        uc_segment[5]=uc_chartable[(TimeHours/10)];
    break;
    // DCF 77 Countdown
    case 3:
        uc_buffer1=59-TimeSeconds;
        uc_segment[0]=uc_chartable[(uc_buffer1%10)];
        uc_segment[1]=uc_chartable[(uc_buffer1/10)];
        uc_buffer1=59-TimeMinutes;
        uc_segment[2]=uc_chartable[(uc_buffer1%10)];
        uc_segment[3]=uc_chartable[(uc_buffer1/10)];
        uc_buffer1=23-TimeHours;
        uc_buffer=uc_chartable[(uc_buffer1%10)];
        uc_segment[5]=uc_chartable[(uc_buffer1/10)];
unsigned char readtast(void)
unsigned char uc_buffer[2];
uc_buffer[0]=PIND&0b00011100;   /* Port B einlesen und Tasten separieren */
delay_ms(10);                   /* 10ms warten */
uc_buffer[1]=PIND&0b00011100;   /* Port B nochmals einlesen und Tasten separieren */
if(uc_buffer[0]==uc_buffer[1])  /* Sind beide Tasten gleich -> Werte zurückgeben */
    return(uc_buffer[0]);
else
    return (0);                 /* Verschieden = Fehler = 0 zurückgeben */
void setup(void)
unsigned int ui_buffer=0;
#asm("SEI")
uc_readtast=readtast();
uc_oldtast=uc_readtast;
while(uc_readtast==uc_oldtast)
    uc_readtast=readtast();     // Warten auf loslassen der Taste
    uc_segment[0]=uc_chartable[24];
    uc_segment[1]=uc_chartable[24];
    uc_segment[2]=uc_chartable[21]; /*P*/
    uc_segment[3]=uc_chartable[24]; /* Leerzeichen */
    uc_segment[4]=uc_chartable[14]; /*E*/
    uc_segment[5]=uc_chartable[5];  /*S*/
delay_ms(100);
// Einstellung delay der Stoppfunktion
while(uc_readtast!=0b00001100)
    if(uc_readtast!=uc_oldtast)
        if (uc_readtast==0b00011000)
            ui_stopdelay=ui_stopdelay+10;
            if(ui_stopdelay>990){ui_stopdelay=0;};
        if (uc_readtast==0b00010100)
            ui_stopdelay=ui_stopdelay-10;
            if(ui_stopdelay>990){ui_stopdelay=990;};
    ui_buffer=ui_stopdelay/10;
    uc_segment[0]=uc_chartable[(ui_buffer%10)];
    uc_segment[1]=uc_chartable[(ui_buffer/10)];
    uc_segment[1]|=0b10000000;
    uc_segment[2]=uc_chartable[18]; /*L*/
    uc_segment[3]=uc_chartable[14]; /*E*/
    uc_segment[4]=uc_chartable[13]; /*d*/
if (ui_stopdelay!=ee_stopdelay){ee_stopdelay=ui_stopdelay;};
delay_ms(100);
// Einstellen des Autoreset wertes
            ui_autoreset=ui_autoreset+100;
            if(ui_autoreset>2000){ui_autoreset=2000;};
            ui_autoreset=ui_autoreset-100;
            if(ui_autoreset>32767){ui_autoreset=0;};
    ui_buffer=ui_autoreset/100;
    uc_segment[2]=uc_chartable[5];  /*S*/
    uc_segment[4]=uc_chartable[22]; /*r*/
    uc_segment[5]=uc_chartable[10];  /*A*/
ui_autoreset=ui_buffer*100;
if (ui_autoreset!=ee_autoreset){ee_autoreset=ui_autoreset;};
delay_ms(100);
// Einstellung Stunden Down Counter
            uc_downstd++;
            if(uc_downstd>99){uc_downstd=0;};
            uc_downstd--;
            if(uc_downstd+1==0){uc_downstd=99;};
    uc_segment[0]=uc_chartable[(uc_downstd%10)];
    uc_segment[1]=uc_chartable[(uc_downstd/10)];
    uc_segment[2]=uc_chartable[22]; /*r*/
    uc_segment[3]=uc_chartable[16]; /*H*/
    uc_segment[4]=uc_chartable[24];
    uc_segment[5]=uc_chartable[13]; /*d*/
if (uc_downstd!=ee_downstd){ee_downstd=uc_downstd;};
delay_ms(100);
// Einstellung Minuten Down Counter
            uc_downmin++;
            if(uc_downmin>59){uc_downmin=0;};
            uc_downmin--;
            if(uc_downmin+1==0){uc_downstd=59;};
    uc_segment[0]=uc_chartable[(uc_downmin%10)];
    uc_segment[1]=uc_chartable[(uc_downmin/10)];
    uc_segment[2]=uc_chartable[19];  /*n*/
    uc_segment[3]=uc_chartable[19];  /*n*/
    uc_segment[4]=uc_chartable[24];  /* */
if (uc_downmin!=ee_downmin){ee_downmin=uc_downmin;};
delay_ms(100);
// Einstellung Sekunden Down Counter
            uc_downsek++;
            if(uc_downsek>59){uc_downsek=0;};
            uc_downsek--;
            if(uc_downsek+1==0){uc_downsek=59;};
    uc_segment[2]=uc_chartable[14]; /*E*/
    uc_segment[3]=uc_chartable[5];  /*S*/
if (uc_downsek!=ee_downsek)
    ee_downsek=uc_downsek;
    ee_downmsek=uc_downmsek;
#asm("CLI")
GIFR|=0b11100000; /*Eventuell anstehende Interrupt Flags löschen */
Third Part of Program:
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=T State6=T State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTA=0x00;
DDRA=0x3F;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 125,000 kHz
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x03;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: 1000,000 kHz
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: On
// Compare B Match Interrupt: Off
// CTC Mode: On
TCCR1A=0x00;
TCCR1B=0x0A;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x27;
OCR1AL=0x0F;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x11;
ui_autoreset=ee_autoreset;
ui_stopdelay=ee_stopdelay;
uc_downmsek=ee_downmsek;
uc_downsek=ee_downsek;
uc_downmin=ee_downmin;
uc_downstd=ee_downstd;
if(PIND.4==0)
    setup();
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Falling Edge
// INT1: Off
// INT1 Mode: Falling Edge
// INT2: On
// INT2 Mode: Rising Edge
GICR|=0xE0;
MCUCR=0x02;
MCUCSR=0x40;
GIFR=0xE0;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: Off
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 38400
UCSRA=0x00;
UCSRB=0x48;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x0C;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
//****** Testroutines
/*uc_dispmode=0;*/
//****** End of Testroutines
// Watchdog Timer initialization
// Watchdog Timer Prescaler: OSC/1024k
#pragma optsize-
WDTCR=0x1E;
WDTCR=0x0E;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Global enable interrupts
#asm("sei")
while (1)
      #asm("wdr");
      if (ui_stopcounter>=ui_stopdelay)
        GIFR|=0b11000000;     /* Anstehende Interrupts löschen */
        GICR|=0b10000000;     /* INT1 = Stopp die Stoppuhr freigeben */
        ub_stopdelay=0;       /* Stopcounter Flag zurücksetzen */
        ui_stopcounter=0;     /* Stop Delay Zähler wieder auf 0 zurücksetzen */
      if(PINB.0>0)
        uc_dispmode=0; /* Pin B.0 mit Pullup =1 -> Stoppuhrbetrieb */
      else
        uc_dispmode=2; /* Pin B.0 mit Schalter auf GND -> DCF 77 Betrieb */
      if(PINB.1>0)
        uc_dispmode++; /* Pin B.1 mit Pullup =1 -> Reversebetrieb der Uhren */
      // Pin D.4 = 0 -> Reset der Stoppuhren
      if(PIND.4>0)
        // Tue nichs
      else
        ub_autoreset=0;
        ub_stopdelay=0;
        ui_stopcounter=0;
        ub_counting=0;
        uc_countmsek=0;
        uc_countsek=0;
        uc_countmin=0;
        uc_countstd=0;
        GIFR|=0b11000000;
        GICR&=0b00111111;
        GICR|=0b01000000;
      // Automatischer Reset der Stoppuhr
      if(ui_autoresetcount<100&&ub_autoreset>0)
        ub_autoreset=0;
        ub_stopdelay=0;
        ui_stopcounter=0;
        ub_counting=0;
        uc_countmsek=0;
        uc_countsek=0;
        uc_countmin=0;
        uc_countstd=0;
        GIFR|=0b11000000;
        GICR&=0b00111111;
        GICR|=0b01000000;
      show_display();
