rs232 serial interface pic16f877
pinky
i want to interface rs232 of pc with pic16f877.
in pic side i like to use inbuilt serial ports
how can use the serial ports of pic16f877
give me some examples for initilize pins,configure serial port,baud rate settingsand everything
Look at my RS232 tutorial at http://www.winpicprog.co.uk, one of the later ones uses the USART in a 16F876.
crust said:
Do you need to use a MAX232 or equivalent on this PIC?
If you want to use the hardware USART you have to have inverters on the input and output (which is what a MAX232 does, and what it's designed to operate with), but if you do software RS232 you can use a simple (crude!) resistor - like the BASIC STAMP does.
To set up the 232 in the pic16f877.h add :
#use rs232(baud=9600 ,xmit=PIN_C6,rcv=PIN_C7)
also youll want to define:
#define puts(s) {printf(s); putchar(13); putchar(10);}
#use fixed_io(C_OUTPUTS=PIN_C6)
#byte port_C=7
in the .c code i used: printf(" hello world");
to sent the string to the serial buffer on the p.c. to my v.b program
hope this helps
#byte port_C=7
hope this helps
MAX 232 CIRCUIT
hai any one there , please provide me with a working ckt dig of max232
which can transmit data from a serial port to something(transmitter)
which can receive data from something(receiver) to serial port
Re: MAX 232 CIRCUIT
Go to the link above to my tutorials, they give all the hardware details as well - including a MAX232 interface.
I need help interfacing max232 to pic16f877. what should i do first and the sample code if you can help me how to initialized it so that i can transmit data between two PIC.
.....so that i can transmit data between two PIC.
For two PICs, one don't need to use MAX232.
If both PICs are on same power supply voltages level, e.g. +5V, and both has hardware USART feature, then just simply connect RX pin of one PIC to the TX pin of another and you are done regarding hardware.
USART to USART
And can any one help me in software for this my amail id is ali.mir10v@gmail.com
I have heard, often, that most PC's do not need level translation. Have not tried it.
You can get the translators in a cable or very small board. There is a short list at:
hi there.
can i know,how to communcate PIC 16f877a to rs232.
how many pins do we need to connect to the PIC from rs232.
is it difficult to program it in C language?
p/s:basically:this PIC will give a command start(triggering) the keithley picoammeter using the communication of rs232 to the picoammeter
