    Dismiss Notice
result is not written to adc register because it has been locked.
Discussion in 'AVR' started by mudassir shah, Jul 19, 2014.
  1. mudassir shah
    mudassir shah New Member
    Jul 19, 2014
    6
    0
    pakistan
    Hello;
    I am fresh here. I am working on atmega8. I want to read analog voltage from its ADC0 pin. I write code for it in mikroc pro for avr. But it gives me error that “result is not written to adc register because it has been locked.” It reads only first simple and then stopped. I don’t know how to solve it??? Anybody have any idea about it? Circuit and code are attached.
    Code is:
    Code (text):
    // LCD module connections
    sbit LCD_RS at PORTD0_bit;
    sbit LCD_EN at PORTD1_bit;
    sbit LCD_D4 at PORTD2_bit;
    sbit LCD_D5 at PORTD3_bit;
    sbit LCD_D6 at PORTD4_bit;
    sbit LCD_D7 at PORTD5_bit;
    sbit LCD_RS_Direction at DDD0_bit;
    sbit LCD_EN_Direction at DDD1_bit;
    sbit LCD_D4_Direction at DDD2_bit;
    sbit LCD_D5_Direction at DDD3_bit;
    sbit LCD_D6_Direction at DDD4_bit;
    sbit LCD_D7_Direction at DDD5_bit;
    // End LCD module connections
    unsigned int ADC = 0,adc_result=0;
    unsigned char display[7];
    void main() {
        Lcd_Init(); // Initialize LCD
        Lcd_Cmd(_LCD_CLEAR); // Clear display
        Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
        Lcd_Out(1,1,"ADC:"); // Write text in first row
        ADIE_bit = 1;
        ADEN_bit = 1;
        ADFR_bit = 0;
        ADIF_bit = 0;
        ADPS2_bit = 1;
        ADPS1_bit = 1;
        ADPS0_bit = 1;
        ADMUX = 0b01000000;
        while(1){
            //ADIE_bit = 1;
            ADSC_bit = 1;
            while(!ADIF_bit);
            ADIF_bit = 0;
            ADC = (ADCH * 256) + ADCL;
            IntToStr(ADC,display);
            Lcd_Out(2,1,display);
    i get error in uploading the circuit.
  2. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    Hello, Mudassir Shah, welcome to ETO!
    I have placed your code inside code tags so that the formatting is preserved. Next time you post code, you can go to the "insert" button, select "code", and paste your code inside the tags. It makes things much neater and easier to read ;)
    As for your question, what is the error you get? It would be very useful to know this information.
    Regards,
    Matt
  3. mudassir shah
    Jul 19, 2014
    6
    0
    pakistan
    i am facing error in uploading image, error is:
    "there was a problem uploading your file. new bitmap.bmp"
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    This assumes you are not allowing enough time to complete the conversion..
    Place a tiny delay after the line...
    ADSC_bit = 1;
  6. mudassir shah
    Jul 19, 2014
    6
    0
    pakistan
    thanks for reply.
    i am not changing ADC channel and and its reference as you can see it in the code.
    according to your instructions, i added 1ms delay but still i am getting the same error.
  7. Ian Rogers
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    We have one or two really good AVR programmers here at ETO... I'm sure one will shed some light on your problem...
    The datasheet locks the ADC registers at the start of conversion, regardless of a channel change. Read the specification in the MikroC manual... I predominantly use Pic's so some AVR functions are alien to me...
  8. kubeek
    kubeek Well-Known Member
    Mar 11, 2006
    1,486
    185
    Prague, Czechia (not Chechnya)
    Are you using atmel studio for this, or some other toolchain? Can you debug the device over jtag?
  9. mudassir shah
    Jul 19, 2014
    6
    0
    pakistan
    i am using mikroc pro for avr and proteus.
  10. Ian Rogers
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    On the MikroC forum the only reference to locked registers is if the port hasn't been set up correctly..
    Check the port direction registers
  11. mudassir shah
    Jul 19, 2014
    6
    0
    pakistan
    i define the port direction according to your instruction. but still i am facing the same problem. new code is
    Code (text):
    void main() {
           ADIE_bit = 1;
           ADEN_bit = 1;
           ADFR_bit = 0;
           ADIF_bit = 0;
           ADPS2_bit = 1;
           ADPS1_bit = 1;
           ADPS0_bit = 1;
           ADMUX = 0b01000000;
           DDRC.F0 = 0;
           while(1){
                ADSC_bit = 1;
            while(!ADIF_bit);
            ADIF_bit = 0;
  12. Ian Rogers
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    Post your problem on the MikroC forum!!
    Why don't you just use the inbuilt function "readAdc()"
  13. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    ADC result register is 16 bit double buffered register. When you read the ADCL (low byte), the 16bit register update is locked until you read the ADCH (high byte).
    If you read ADCH first and then ADCL, the register will stay locked, preventing any new conversion to be written in the result register.
    (And do not use variable names like "ADC", that may already be reserved).
    Code (C):
    /* Safe way to read ADC result register */
    adc_result = ADCL; /* Read the low byte */
    adc_result += (ADCH<<8); /* Read and add the high byte */
    Also, you may have serious problem here:
    The variable "ADC" may already be defined as the adc result register.. and writing to that is not allowed. Change the name of that variable.
    • Agree Agree x 3
    • Thanks Thanks x 1
  14. mudassir shah
    Jul 19, 2014
    6
    0
    pakistan
    thanks MisterT, now its working.
  15. Ajit Jadhav
    Ajit Jadhav New Member
    Oct 27, 2015
    1
    0
    I was also going through same problem :(.. Thanks:)
Share This Page
