2PAC Mafia
Hi guys,
in the past I already had to repair this unit with problems at power supply. I had to replace these components:
U101 = L6598D
R101 = 10 ohm
R102 = 33 ohm
Q101 = STP9NB50FP (installed STP9NK50Z)
Q102 = STP9NB50FP (installed STP9NK50Z)
D101 = K6 (MMBD914L1) (installed KA2 = MMBD914-7-F)
D102 = K6 (MMBD914L1) (installed KA2 = MMBD914-7-F)
This time, again the equipment with problems at power supply so I replaced :
R101, R102, R103, R104, Q101, Q102, ZR101 and U101
After replacing them I see how at pin 12 of U101 are only coming 4V so I tested the resistor divisor R121, R122, R155 and R156 and all are right.
I tested the output of U101 only connecting 11Vdc to see if it works and it does. Now I don´t know why I get only 4V so the U101 is not starting up the power supply.
I attach the schematic:
http://www.restoretronic.com/descargas/sd254165_1_3_02 Shematic Fonte .pdf
May be you can give some idea.
U101 = L6598D
R101 = 10 ohm
R102 = 33 ohm
