    Dismiss Notice
PWM to Analog Converter
Discussion in 'General Electronics Chat' started by engineergc, Sep 8, 2017.
  1. engineergc
    engineergc New Member
    Oct 26, 2016
    26
    0
    Dear All;
    I am trying to convert PWM to analog signal without any software. I tried use RC filter but freqeuncy range of PWM signal is 5 Hz to 500 Hz, so I can not use RC filter. I searched PWM to analog converter entegres, but their minimum frequency starts from 30 Hz. How I can convert pwm to analog in specified range without any software?
  2. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,018
    317
    Brisbane Australia
    ONLINE
    What produces PWM that varies in frequency? PWM is normally at a fixed frequency and the on/off ratio is varied. Can you give more details about the signal?
  3. engineergc
    Oct 26, 2016
    26
    0
    I have PWM signals that have different frequencies. I want to convert them to analog signals. Min. frequency of pwm signals is 5 Hz and max. frequency is 500 Hz.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Pommie
    Mar 18, 2005
    10,018
    317
    Brisbane Australia
    ONLINE
    PWM stands for pulse width modulation, there is no variable frequency, just variable width. Unless you can describe the signal better then I can't help you - repeating your previous post doesn't help.
  6. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    500hz = 2mSeconds
    5hz = 2oomS
    It is possible that you have a system where the "on time" is 2mS and the off time is variable from 2mS to 200mS in 2mS steps.
    (or the reverse of that)
    _-_-_-_-_-_-=fast and high dutycycle
    _-_________-________=slow and low dutycycle
    **************OR************
    Maybe you have different PWMers. One runs at 5hz and another runs at 500hz.
  7. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,048
    541
    AZ 86334
    Read this post. This is normally how you filter 500Hz PWM to produce a proportional DC level. Note the settling time. If you start with 5Hz PWM, it will take 100 times longer for the DC level to respond to a step change of the PWM duty-cycle.
  8. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Perhaps, you really just need a frequency to voltage converter, as is sometimes used in tachometers. There are single chips to do that.
    John
  9. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,445
    936
    Canada, of course!
    Some birds flap their wings at 5Hz.
    I agree that it will take a long time for a filter to settle when the 5Hz PWM has very narrow pulses.
  10. simonbramble
    simonbramble Active Member
    Nov 22, 2010
    430
    63
    this part is what you are looking for:
    http://www.linear.com/product/LTC2645
    ... although your frequency is a bit low. We designed this part for people who cannot change their software, but want an instant response DAC output instead of using a low pass filter and the inherent delay that it introduces
    • Like Like x 1
  11. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    :p:p:p:p:p:p -- a dude from linear ;););)
  12. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Can you substantiate that claim?
    John
    • Thanks Thanks x 1
  13. schmitt trigger
    schmitt trigger Active Member
    May 24, 2009
    886
    84
    I believe that Simon has introduced himself previously as either a LT employee or rep.
    In any case, I have no problem with him providing suggestions. LT is a superb semiconductor company with a wide and innovative product portfolio.
  14. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    is from where you recon a true hardware engineer - all tough the app is up and running - there's a possibility it runs from the wrong bases (this' - about the nomination)
    such has happened (namely the deviceĀ“s operating range was narrow - and it didn't work because of what i thought it did) -- as there's a possibility someone passing a typo or miss wording
    (thinking of -- people who can design Op Amps are here - muhahaa - this is so sillily cool :woot:)
  15. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Wow, what a "sentence." It is completely incomprehensible to me.
    Back to my original comment, it would help if I knew what " :p:p:p:p:p:p " and " ;););) " meant. The former apparently translates to "stick out tongue" and the latter to "wink". So, six tongues and three winks means what? How does that modify that he previously worked at Linear? Are you suggesting it is good, bad, or that his suggestion is clouded by that fact?
  16. simonbramble
    Nov 22, 2010
    430
    63
    To be correct, I am now a dude from Analog... and no, I did not understand the sentence either (!). It sounds like an output from Google Translate. Thanks for the compliment on the product range. It is much appreciated :woot:
  17. schmitt trigger
    May 24, 2009
    886
    84
    Make it three
  18. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    it's about sincere happiness . . .
    [​IMG]
    :p:p:p:p:p:p:p:p:p ! BOOM ! :) thinking of . . . centuries of pollution and contamination :woot:
    ((as in fact i think the china only should and can deal with those guys . . . in guiding their efforts to a longer perspectives ... for everyone ...))
    as what to admire about this people is the capability to incorporate the existing no resources to actually output anything // in contrast to our plentiful world where the only brake is not getting along with each other o_O . . . continuously as and in this forum most unfortunately
  19. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,254
    1,218
    Cardiff, Wales
    Hmm. Don't think much of their manufacturing quality control. The nose cone of the missile in that pic is way off from the template. Makes you wonder how far off target the flight end-point would be! :eek:
  20. schmitt trigger
    May 24, 2009
    886
    84
    That image is inside a laboratory or building.
    Yet, Kim is wearing a heavy, fur lined coat and hat.
    There is absolutely no heating in the building!
    And that is in premier lab.
    This image is not unique. There are many pictures of Kim touring rocket and weapons labs, showing the same garments.
  21. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    v-.-v Hi! Mr. Linear-Analog-Bomb :D:D:D
    :p (too catchy not to be posted) muhahaa
Share This Page
