    Dismiss Notice
Pwm resolution concept
Discussion in 'Microcontrollers' started by elecLear78, Jun 1, 2017.
  1. elecLear78
    elecLear78 Member
    Jul 16, 2013
    226
    1
    india
    Iam bit confused with pwm resolution in pic controllers. Generally i am using the following equation to calculate ptper reguster
    Frequency of clock/ pwm frequency = ptper value. The duty cycle is loaded based on the value of ptper value
    Pdc = ptper * duty cycle / 100.
    Now my confusion is the pwm resolution. What exactly is this, should i calculate everytime. Please advise.
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,165
    910
    Rochdale UK
    ONLINE
    Try to think of it this way...
    - Timer 2 will count until it equals PR2 and then it starts again this is the frequency..
    - CCPRxL combined with the two DCB bits in the CCPxCON determine when the pin is high or low..
    - If Timer 2 < CCPRxL + DCB1+DCB2 then the pin is high otherwise the pin is low...
    The best explanation is in the pic12f1840 datasheet....
    Don't let the register name upset you... These are the original names...
    Once the ptper (PR2 ) is set and the Timer is configured... All you need to change is the CCPRxL ( OCxR) register.
    What chip are you actually using...
  3. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,899
    502
    Cleveland, OH, USA
    ONLINE
    Resolution is the number of steps (e.g., duty cycle values) allowed between the lowest value (often 0% ) and the highest value (often or close to 100%).
    This site will calculate the register values and show how many resolution bits there will be in the results.
    http://www.micro-examples.com/public/microex-navig/doc/097-pwm-calculator.html
    John
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. hugo
    hugo New Member
    Aug 9, 2003
    18
    0
    You can think of resolution like the number of segments needed for the 'period' of time, so for 10 bit there are 1024 segments.
    A 50% duty cycle means that for 512 segments the signal is on and for 512 segments is off.
  6. elecLear78
    elecLear78 Member
    Jul 16, 2013
    226
    1
    india
    Ok Thank you very much, now i can understand.
  7. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,049
    541
    AZ 86334
    If you perfectly low-pass filter the PWM signal to a DC level, and the PIC is powered with 5.000Vcc, then you get 1023 = ((2^10)-1) equal steps from 0V to 5.000V*1023/1024 = 4.995V. The step size is 4.995V/1023 = 0.00488V
  8. MikeMl
    Mar 17, 2009
    11,049
    541
    AZ 86334
    Hello Pradeep. Your question should really be posted in its own (new) thread; not appended to an existing thread which discusses a different topic...
    In LTSpice, there is a generic multi-winding transformer model which can be customized with a few parameters. I dont know how to do that in Proteus.
  9. Pradeep kumar Dharkar
    Pradeep kumar Dharkar New Member
    May 30, 2017
    2
    0
    Thank you Mike Mi
Share This Page
