    Dismiss Notice
PWM mode vs dirty
Discussion in 'Robotics & Mechatronics' started by Makaram, Oct 14, 2012.
  1. Makaram
    Makaram Member
    Mar 24, 2011
    153
    0
    Dunedin, NZ
    Hey guys,
    writing c code for pwm controlling 4 servo's and as far as I can tell, the dirty method seems infinitely easier than using the proper pwm method (which I have yet to get my head around).
    What is the point in using pwm mode rather than simply doing the work in code?
  2. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    What's "dirty mode" ?
  3. Makaram
    Makaram Member
    Mar 24, 2011
    153
    0
    Dunedin, NZ
    Doing in code
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Hardware PWM is not very practical for servo motors. Software is the traditional method.
  6. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    Hardware PWM lets the processor spend it's time doing other things. Software PWM eats up processor power and is more sensitive to the processor load since it is a time dependent task running alongside other tasks. If the PWM hardware module allows you to have time pulses long enough for operation with RC servos then it is best to do that.
  7. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    There's the rub, most microcrontrollers don't run the PWM slow enough for effective servo control. Also most have only one or two actual PWM controllers.
    It's easy enough in software, using interrupts is the way to go.
  8. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    The usual refresh rate for model servos is 50Hz. Analog servos will operate OK to about 100 to 120 Hz, which gets you to the lower limit of PIC hardware PWM, but the resolution might not be what you need. I had read somewhere that digital servos can go even higher. I can'f find that source, but if you search on "digital servo refresh rate" you will find lots of comments that they will tolerate 300Hz. Here is one thread: http://www.multiwii.com/forum/viewtopic.php?f=8&t=1644
    Of course, one can also find out how to make cars run on water on the Internet too. So, I can't vouch for the reliability of that number. It should be easy enough to test with a digital servo. They are quite cheap now, and the ones with 8 ┬ÁS deadband (standard) should be more than adequate for that purpose.
    John
    Edit: I forgot to say that I agree with Bill about using software. The above was written from the standpoint of someone who wanted to use hardware or in a situation, such as a latch, where hardware might be simpler.
  9. Makaram
    Makaram Member
    Mar 24, 2011
    153
    0
    Dunedin, NZ
    Thanks for your reply's. My initial though was also that hardware pwm didn't seem very practical as it would require constant changing of multiple registers and calculations. I think i'll go ahead with the software approach as I've already got some experience with this anyway.
    Thanks again
  10. MrAl
    MrAl Well-Known Member Most Helpful Member
    Sep 7, 2008
    11,029
    951
    NJ
    It's called "bit banging" implying that you bang the bit either 0 or 1 and that does all the work.
    But with software PWM then the software is loaded down unless of course you're not doing anything else anyway.
    One of the moon missions almost didnt make it back because of software overloading...not enough time to perform all the required tasks. If you have the time however then there's no problem. So it's really a matter of if you have the time in clock cycles or not. If you really didnt have the time you'd before forced to use the on board hardware.
  11. kinarfi
    kinarfi Well-Known Member
    Jul 7, 2009
    1,503
    30
    P. G., Utah, United States of America
    I hope this isn't a hyjack, although it may be, does any one know of a radio control type PWM chip for decoding the 1 - 2ms pulse? other than the NJM2611 by JRC,(analog) or the Renesas M64611FP (digital) which Renesas says is not available any more. I'd like to find a source for digital decoder if possible.
    Kinarfi
  12. tomizett
    tomizett Active Member
    Aug 11, 2013
    419
    45
    UK
    Also of course, a hardware circuit would probably be a better solution if you want a regulator-type system with current or voltage feedback.
Share This Page
