[Project] Voltage problem on Smoke device , need help
zerostar
i am building a smoke device,
https://www.youtube.com/watch?v=F3q4GHofWfY
and getting some trouble on the voltage problem.
The device separate into 3 part, motor, heater, battery( 4 * 1.2V rechargeable battery) .
and 3 of them is connected in parallel .
Here is the problem :
1. motor do not receive enough to run (after test, it only got 1.9V . And heater got 1.5V )
Hi,problem had been solved,
the main reason is wire problem, after changing wire, everything become alright.
By the way, another is multi meter reading problem,
When I switch to 200mA, it showed 11.0
When switching to 20mA, it showed 0.94,
I am confused on such number...
I'm guessing the connecting wires are dropping too much voltage. Different lengths/thickness of wires will drop different amounts. What gauge wire are you using? How much current do the motor and heater draw?
you've put a link to a video, but what is the schematics?
do you want us to guess just looking at the mess on the table?
Opps, tell u later after checking.
wire : 1mm to 2mm
current (motor); 0.0019A
current (heater): 0.0017A
let me know if i do anythings wrong
I suspect that there is something wrong with your meter or your measuring technique.
With a 4.8 volt supply, those currents represent far too little power for a motor or a heater.
Battery output: 4.59V
Voltage (motor): 3.66V
Voltage (Heater): 2.95V
Current: 1.1MA
This does not make any sense.
Can you post a picture of your set-up and how you are making the measurements?
Have you set your meter correctly for measuring DC current and DC Volts, with the probes plugged into the correct sockets on the meter (DC Amps usually uses a different socket from DC Volts)?
Your meter could be damaged if you tried measuring a current much greater than 20mA on the 20mA range :(
Yes, 11mA.
See post #14 :)
