    Dismiss Notice
power saver circuit
Discussion in 'General Electronics Chat' started by plodhi2002, Aug 27, 2006.
  1. plodhi2002
    plodhi2002 New Member
    Jul 4, 2006
    6
    0
    Could anyone tell me what sort of circuit is used in power savers commonly available on the net by mail order. these can be plugged into home sockets so that you have less usage of electricity especially when you use a/c in summer or fridge and deep freezer. one method i saw on net was to fit a mains capacitor to correct power factor across the motor terminals. Are there any other electronic circuits for reducing voltage to reduce electricity consumption of a/c motors?
  2. Marks256
    Marks256 New Member
    Jul 14, 2006
    2,350
    9
    Minnesota, USA
    There is a reason why they take the amount of power they do; SO THEY WORK PROPERLY! :eek: If you try to do something to use less power to them, then you will make them less efficient at the job they should be doing. If you want to cut on A/C costs, get a few fans. They are about $20, and they work awesome. :)
  3. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    That's right they are mearly power factor correction devices. Motors and other inductive loads draw a lagging current, all these units do is introduce some capacitance to ballance it an lower the current consumption. They do not actually lower the power consumption of the device itself, they just reduce the current consumption. Power is saved but only because the current is lower hance the R squared I losses are lower.
    These units won't reduce your bill by much as you're most likely billed by the power you use rather than VA. However these power savers are still a good idea since the save losses in the cables and therefore they're good for the enviroment.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. sonamoni.ng
    sonamoni.ng New Member
    Apr 8, 2009
    1
    0
    I need a power saver circuit diagram with specification.
  6. tcmtech
    tcmtech Well-Known Member Most Helpful Member
    Feb 22, 2009
    6,531
    414
    Sawyer, North Dakota, USA
    There is actualy a energy saving device called a Watt Wizard or a Green Plug. It slightly varies the voltage going into a inductive load type devices like air condioiners, refrigerators and freezers. It varries the voltage proportinaly to the to the load to keep the internal inductance losses down.
    In some devices the induction motor is running a very light load at times. If the incoming line voltage is dropped to a lower level the total energy loss in the motor goes down. Being able to reduce the line voltage when the load is light will save energy.
    It does actualy reduce the total wattage a device uses but not much. I have had one for about 15 years. I have in fact ran it through an actual spinner type watt meter and found that it does in fact Work! BUT the actual savings is small.
    Its the only energy saving device on the market that I have found that actualy does some small but measurable good!
    For what one costs it would still take years to pay for itself by avoided cost comparison.
  7. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,192
    916
    Canada, of course!
    Industry is billed extra if their power factor is poor. A home is not because a home's meter ignores a poor power factor.
    The "energy saving" device is just an over-priced capacitor. Its value might be too high or be too low. It saves money for the electrical utility if its value is correct for your inductive appliances but since the appliances turn off and on then the capacitance is frequently too high so it costs the electrical utility more, not less.
  8. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    I would hope that it's an array of capacitors which are connected or disconnected according to the power factor.
  9. JLO
    JLO New Member
    May 27, 2009
    2
    0
    Philippines
    I just installed one in my water pump last week, got the power saver from china with brand name 'Power Star'. Upon checking, using a clamp meter, i got 0.4amps reduction which if i multiply with line voltage of 230VAC, i can reduce around 90watts. I hope this can give some savings on the actual bill as well..
  10. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    And how are you measuring the efficiency of the pump? Reducing current isn't going to increase efficiency if the pump just has to run longer. You can't get something for nothing.
  11. tcmtech
    Feb 22, 2009
    6,531
    414
    I suspect its similar in operation to the watt wizard I have. It will save but the realistic savings will not likely ever off set the purchase cost!
    I still watch auctions and garage sales for them though. If you pay under $3 they are cost effective! :D
    For refrigerators, freezers, water pumps, heat pumps, and air conditioners they do work but not as great as they advertise! :(;)
    If you get the chance to buy one used for cheap get it! You can spend more money on worse stuff! :p
  12. JLO
    JLO New Member
    May 27, 2009
    2
    0
    Philippines
    Mine was free as a gift from a friend. If you will buy it here, it'll cost you $USD15. About the actual savings i'm not really sure..have to wait for the actual bill.
    For the pump effeciency, i don't have other test aside from above but i think 0.4amps doesn't affect at all (pump rated 1HP)... and yes i agree the product isn't work as advertised... if mine really works.. it only gives around 7~8% reduction.
    Thank you guys for your comment...:)
  13. tcmtech
    Feb 22, 2009
    6,531
    414
    Mine was free too!
    The only reason I know they work a little bit is because I am rather skeptical of such devices and I have ran mine through an actual standard spinner type watt hour meter and did time based testing with different electrical devices.
    There was honest power savings but only about 5 - 15% from one device to another. Compressor based cooling devices were typically the highest. Standard induction motor mechanical drive devices were the lowest.
    I think the compressor type devices were only able to save a bit more because of the way the cooling system will interact with a slightly slower running motor.
    Slower compressor speeds make the coolant gas peak pressures lower and thusly further reduces the energy required to pump it.
    Mechanical loads are typically reasonably fixed loads so the only energy savings is from being able to reduce the line voltage going into the motor. That in turn cuts down on internal motor losses. But only slightly.
  14. amitgoel1976
    amitgoel1976 New Member
    Aug 31, 2009
    1
    0
  15. Marks256
    Marks256 New Member
    Jul 14, 2006
    2,350
    9
    Minnesota, USA
    lol!!!!!!!! :D
  16. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Why it's so easy to cut and paste. :)
  17. tcmtech
    Feb 22, 2009
    6,531
    414
    By the time you build one yourself and run it until it pays for itself in avoided costs on any type of home appliance you will be to old to care. :(
    If its just because it good for the environment, grow up. Go outside and pick up garbage on the streets in your neighborhood and local community and you will get recognition and exercise at the same time and far more personal 'gone green' bragging rights too! Plus the environment will be much further ahead if you do. ;)
    Sorry to be blunt like that but some days it just needs to be done.
    If your really looking to save energy just use less electrically powered stuff or turn it off when your done! :)
  18. blueroomelectronics
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    For once we see eye to eye :)
  19. tcmtech
    Feb 22, 2009
    6,531
    414
    Just for once? I find what you have to say interesting and informative. You may not like my views and approaches on how to do some things but still I always rate yours pretty well! :)
    Besides I need guys like you to make me think some days! ;):D
    Just dont bust my chops every day. It starts to come off as obsessive and unhealthy at some point. :eek: :p
Share This Page
