    Dismiss Notice
pls help- mosquito racket repair
Discussion in 'Repairing Electronics' started by takne007, Apr 9, 2009.
  1. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    hello
    i joined this forum today. i purchased a mosquito racket. now its not working. please tell me ,how can i trouble shoot this.
  2. forumlicker007
    forumlicker007 New Member
    Mar 23, 2009
    166
    3
    USA
    What exactly happened takne? Is it oscillating or dead?
  3. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    it's not oscillating. so,how do i troubleshoot? transistor is the oscillator,right? there is a transistor.looks like a FET, actually. i don't know how to check a FET. the number is "H SD 965". the transistor is not available.please help.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    Is it under warranty?
  6. forumlicker007
    Mar 23, 2009
    166
    3
    USA
    FET only. Might be a faulty one I guess. Replace it, before that check 1.5vx2 power supply coming to the board or not. Maybe problem with X'former. You've to check it thoroughly.
  7. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    the bat is made in china.no guarantee.pls tell me how to check the transformer.
  8. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    2SD965 is a bipolar junction transistor. You can check it with an ohm meter. Scan this forum for the method.
  9. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    could some one tell me the equivalent of 2SD 965 transistor? there is a transformer(driver transformer i think) in the bat. how to check it? where can i find them?
  10. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    Where you can find them depends a lot on your location and your resources.
  11. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    i live in India.
    I have tested the transistor using digital multimeter in diode testing position. voltage between emitter and base is 1.05v and between collector and base is 0.65v. what does it mean that the transistor is bad?
  12. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    for the second time of requesting, what is the replacement for 2SD 965 TRANSISTOR?
  13. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    That means the transistor is probably good.
    Not knowing the exact circuit, if a TIP31 fits (I know it is bigger) I would try it. The gain is not the same but the circuit is probably a blocking oscillator and wouldn't care.
    I don't know what transistors are commonly available in your town, but now that you have said you are in India, perhaps one of the forum members who can help will speak.
  14. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    so, the transistor is good.then,please explain,why it is showing 1v between emitter and base,instead of .65 volts drop. may be the problem with the transformer. pls tell how to check it.
  15. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    I said the transistor is probably good. With some transistors 1.0V is close enough to 0.65V, others it is not. Also check between E and C.
    To check the transformer, identify the windings and check continuity. This is probably fruitless because the problem could be high voltage arcs that only appear when it is trying to operate.
    To proceed further you probably need to reverse engineer the circuit. By this time I would be buying a new one and taking this one to e-waste disposal. But that's just me.
  16. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,430
    933
    Canada, of course!
    Look at Mosquito Repeller in Google. Those ultrasonic noise makers do not repel mosquitoes. Your government needs to put larvacide in every pond and rain catch basin like mine did. Now all the mosquitoes and the bats that ate them are gone.
  17. mneary
    mneary New Member
    Feb 27, 2007
    4,502
    67
    California USA
    Uncle $crooge, look at Mosquito Racket in Google. It's a zapper in a tennis racket that you wave at mosquitoes. Equally pointless, but a lot more fun.
  18. audioguru
    Mar 16, 2004
    32,430
    933
    Canada, of course!
    The history of the extremely cheap Mosquito Racket zapper shows that they either do not work or they fail in a few days.
  19. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    For every one you kill 9 others will bite you anyways.
  20. takne007
    takne007 New Member
    Apr 9, 2009
    11
    0
    India
    i use a liquid mosquito repellant. my goal is only to study and understand the circuit. i want to turn that thing into a stungun, with some multiplier circuits of course.
  21. Hayato
    Hayato Member
    Jun 21, 2006
    694
    14
    BR
    Multipliers circuitry are very unefficient and have very high impedance output.
    You racket have a very low current output and if you add a a multiplier circuit it will become useless.
Share This Page
