Pls Help me build this circuit
Fuad
Hi, i need help i would to have the following but dont have any idea how to do it:
- i would like to have a micro controller pref. PIC16F84 circuit with 4 switches connected to it VSource1, VSource2, VSource3, VSource4 these switches would be the input for the output i want it to do 2 things
a) always when the power is on the PIC assumes Source1 is on if any switche is pressed the micro controller would send a pulse to the source connection coressponsing to the source if source3 is pressed it would send 2 pulses which simulates if the source switch is pressed twice, then it will store the current souce if source4 is pressed it will send 1 pulse
b) coressponding to the sources there are 2 audio souces. audio source1 would be for VSource1, Vsource3 and VSource4, audio source2 would be for VSource2 i want the PIC to control the 2 audio sources accordingly.
i dont know how to design the audio source circuit in has 2 inputs and 1 output with PIC controlling which source is on.
also i would like to know how to make a voltage regulator with the following values:
inout voltage is Car 12V
1) 12V 1.25A Voltage Regulator
2) 5V 2.4A Voltage Regulator
Thank you
