Please Help me with reading the busy flag of LCD in 4 bit mode
aakashjsr
I am able to execute commands on my lcd when I use delay instead of checking the busy flag but when I check the busy flag,it appears as if an infinite loop has started.Here's the connections for my 4 bit Lcd with the AVR Atmega 16.Thanks a lot in advance :)
PB0-> RS ; PB1->ENABLE ; PB2->R/W ; PB3->NOT CONNECTED
PB4-PB7----->DB4-DB7
************************************************** *************************** Code:************************************************** ***************************
C:
#define data PORTB
#define e PB1
#define rs PB0
#define rw PB2
void lcd_ready() //checks for busy flag
    DDRB&=0b00001111; //data lines as read
    int flag=0;
    cbi(PORTB,rs);
    sbi(PORTB,rw);
    do
        pos_pulse();
        _delay_us(10);
        flag=PINB;
        flag=(flag&0x80); //to store the value of busy flag
        pos_pulse(); //discard lower nibble
        _delay_us(10);
        }while(flag);
    DDRB=0xff; //resetting data lines as output
void pos_pulse()
    cbi(PORTB,e); // eable=0
    _delay_us(2);
    sbi(PORTB,e) ; // eable=1
    _delay_us(2);
void neg_pulse()
    sbi(PORTB,e); // eable=1
    _delay_us(2);
    cbi(PORTB,e) ; // eable=0
    _delay_us(2);
void command(int a) // to receive and send command to LCD
    //higher nibble
    lcd_ready();
    data=(a&0xf0);
    cbi(PORTB,rs);
    cbi(PORTB,rw);
    neg_pulse();
    //Lower Nibble
    lcd_ready();
    data=((a<<4)&0xf0);
    cbi(PORTB,rs);
    cbi(PORTB,rw);
    neg_pulse();
void value(int a) //To send Data to the Lcd
    //higher nibble
    lcd_ready();
    data=(a&0xf0);
    sbi(PORTB,rs);
    cbi(PORTB,rw);
    neg_pulse();
    //Lower Nibble
    lcd_ready();
    data=((a<<4)&0xf0);
    sbi(PORTB,rs);
    cbi(PORTB,rw);
    neg_pulse();
I don't have time to go through your code right now, but I found this short and well documented example. Maybe this will help you find what is wrong with your code:
Thanks a Lot,the documentation of the code provided really helped.I would really appreciate if in your free time you could go through my code and point out the mistake.Thanks Again :) :)
