    Dismiss Notice
PicBasic Pro, PicBasic Plus, Proteus Download
Discussion in 'Microcontrollers' started by sonsivri, Oct 1, 2003.
  1. sonsivri
    sonsivri New Member
    Oct 1, 2003
    2
    0
    I have updated my web site from hatshepsut.virtualave....
    The new address is www.sonsivri.com
    you can download PicBasic Pro, PicBasic Plus, (proteus not now) full versions.
    Entertainment and knowledge is coming.
  2. Flamer1
    Flamer1 New Member
    Oct 6, 2003
    18
    0
    Hey, I got your PicBasic Pro and I'm having trouble with your software. It compiles correctly, but doesn't work like I'm expecting it to. It should output "Hello World" onto the screen using Hyperterm. But I don't get anything.
    Include "bs1defs.bas"
    DEFINE CHAR_PACING 1000
    Serout PORTB.1, N2400, [15]
    START:
    High PORTB.0
    Pause 1000
    Serout PORTB.1, N2400, ["Hello World"]
    Serout PORTB.1, N2400, [10]
    Low PORTB.0
    Pause 1000
    Goto START
    End
    and here is another program that does similar function, but doesn't work either
    DEFINE CHAR_PACING 5000
    START:
    PORTB.0 = 1
    Pause 1000
    Serout PORTB.1, N2400, ["Hello", 10, "World"]
    PORTB.0 = 0
    Pause 1000
    Goto START
    End
    does your software not work correctly with P16C765 chips??? do you have an unaltered version of the software?
  3. ivancho
    ivancho New Member
    Aug 20, 2003
    333
    0
    Kansas
    I am guessing you have the UV ereasable version of the P16C765....
    how do you have it connected?
    What crystal do you have?
    Are you sure that the grounds between PC and PIC are connected?
    What voltage levels are you using for serial transmition?
    Are you using a MAX232?
    Are you connecting it straight to the PC?
    Is your PC set for 2400 baudrate?
    :!: There are some things you are missing as well:
    - You are not defining your TRIS registers.
    - Include "modedefs.bas"
    Try this:
    Code (text):
    TRISB = 0
    START:
    High PORTB.0
    Pause 1000
    Serout PORTB.1, N2400, ["Hello World", 10]
    Low PORTB.0
    Pause 1000
    Goto START
    End
    I hope this helps you some
    Ivancho
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Flamer1
    Flamer1 New Member
    Oct 6, 2003
    18
    0
    thanks
    yes, I didn't have the TRISB register defined. I checked out the following things
    1). ground between PC & PIC is connected
    2). i'm using inverted 2400baud, 8N1 directly from PIC to PC at 0-5V
    3). i'm using a 4MHz crystal
    the code will run and execute on a 16F877A, but the same code compiled for the 16C765 will not work. Is it because of the modified PicBasic Pro compiler used?
  6. ivancho
    ivancho New Member
    Aug 20, 2003
    333
    0
    Kansas
    Did you change the settings so that it compiles for a P16C765 instead that for the 16F877?
    Are you sure that the PIC is ereasable and not OTP chip? Are you setting the chip to accept external oscilator? Can the P16C765 blink a LED.... is it alive?
    From the datasheet:
    good luck
    Ivan
  7. Flamer1
    Flamer1 New Member
    Oct 6, 2003
    18
    0
    Thaks for the replies
    1). Yes it is compiling for the 16C765
    2). No, it isn't a OTP chip, it is UV, and has been erased
    3). I can get an LED to blink, so the chip is somewhat functional
    4). The chip is set to HS mode for an external oscillator
  8. ivancho
    ivancho New Member
    Aug 20, 2003
    333
    0
    Kansas
    Did you program the PIC with the code I posted? Does the LED ( + resistor) blink on portB.0. That code works well over here :?
    :arrow: A schematic of how you have everything connected would help a lot. Can you connect something into the serial port to make sure the port is working? The HS setting is for high speed, try porgramming it with a XT option or crystal option insead and see if that makes a difference.
    In my computer there are 2 serial ports and I always have to double check that the one I am talking to is the one I open. It might apply to you too.
    If your PIC blinks there is a problem most likly on the PC side. Perhaps not the right baudrate, if you get something but is not what you sent try sending in non-inverted. Try at 9600 baudrate.
    Let me know who it is going
    Good LUck
    Ivan
  9. trutan
    trutan New Member
    Oct 15, 2003
    3
    0
    Makati
    Thanks for posting the software! Really appreciate them.
    .. Why are there several versions of Picbasic Plus v1.24X?
  10. lzgq
    lzgq New Member
    Sep 12, 2003
    3
    0
    didn't DL proteus C*R*A*C*K
    [​IMG]
  11. lzgq
    lzgq New Member
    Sep 12, 2003
    3
    0
    [​IMG]
  12. Robertino
    Robertino New Member
    Nov 12, 2003
    7
    0
    Thx for the software, i already have a old 2.33 of PBP (regularly paid) and not undestranding whi this kind of minor update are not freely avalaible on melabs website.....
  13. sonsivri
    sonsivri New Member
    Oct 1, 2003
    2
    0
    "trutan"
    There are archive. This for a different syntaxs in source code.
    Maybe you need the old versions :)
    "Robertino"
    You can download 2.43 version now from my web site.
    New tools:
    Pic Basic Plus 1.4j, 2.1
    Pic basic Pro 2.43
    MicroCode Studio Plus 2.0.5.2
    Proteus 6.2 SP4
    PicC (PCW)
    Hitech PicC
    Bascom-Avr
    Bascom-8051
  14. Robertino
    Nov 12, 2003
    7
    0
    thanks....
    hey, do you have or know where download :
    Salvo RTOS library for pic ? (not the lite version) ???
    thx Roberto
  15. CoTang
    CoTang Member
    Dec 12, 2003
    77
    0
    Any chance I can get pbpro 2.44? I can't download it off your site.
  16. karenthestudent
    karenthestudent New Member
    Dec 8, 2003
    20
    0
    ivancho CAN YOU HELP PLEASE?
    hi, it seems that you would be able to help?
    I have posted a long series of replies to explain what difficulties I am having. Please see 'Karenthestudent' under micro controllers?
    thank you
    (anyone that could help would be great) :?:
  17. fredm
    fredm New Member
    Dec 24, 2003
    1
    0
    The page to download thr picbasic pro is dead?
    Any ideas how I can download the picbasic pro 2.44?
  18. Rescyou
    Rescyou New Member
    Nov 8, 2003
    81
    0
    Alberta, Canada
    Ummm Buy it?
  19. moni1
    moni1 New Member
    Oct 1, 2005
    1
    0
    i can't enter to sonsivri.com why?
    Deleted by moderator
    This site isn't for requests for pirate software
  20. akg
    akg New Member
    Sep 2, 2005
    1,404
    1
    India
    Your post is deleted as well!.
    DO NOT post links for pirate software!.
Share This Page
