Pic32 Not Working with 18.432MHz Crystal
rmrps
I am using 18.432 MHz Crystal and Pic32MX460F512L Microcontroller with 22pf capacitor, i am having the following configuration settings but the controller not working it's get hanging
#define SYSCLK 147456000L
#define PBCLK (SYSCLK/2)
#define Fsck 50000
#define BRG_VAL ((PBCLK/2/Fsck)-2)
#pragma config FPLLMUL = MUL_16, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_8,FSOSCEN = OFF
#pragma config WDTPS = PS1048576
the program get stuck in
SYSTEMConfig(SYSCLK, SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
after the above line the controller get hanged
I guess my configuration setting is the issue please guide me to resolve this issue.
If you use a crystal at that speed I very much doubt you can use any multiplier, PLL or Divider..
If you look at the PIC32 excel sheet ( from Microchip) that crystal isn't listed.
All will need to be 1 and that will limit your pic32 as you cannot achieve any higher bus speeds... You'd be better off with a pic24..
Why do you need a 18.423 ?? If its for RTCC or BAUD.. You can set a second crystal on OSC2...
