pic16f886 uart + AT problem
urgh i am still trying the 2 codes out...something wrong with my pickit2 at the moment.
btw, i just thought of smth, do we need to expand the TXREG and RCREG code segments in future?
like lets say if i should get a certain response from the AT module if i transmitted something? maybeeee, when i press the switch and it transmits the word "AT", i should get a reply of OK from the bluetooth or something?
oh i remembered u once said that i need to initialize the m_Count. am i right to initialize it to m_Count =0? cos i dont think it worked last week
Hmmm
	#include<pic.h>
	#include<htc.h>
	#include<conio.h>
	#include<stdio.h>
	#define XTAL_FREQ 8MHZ
void init_rs232();
//void putChar( unsigned char ch);
#define MHZ *1000L
#define DelayUs(x) { unsigned char _dcnt; \
_dcnt = (x)/((12MHZ)/(XTAL_FREQ))|1; \
while(--_dcnt != 0) \
continue; }
int m_Count;
//m_Count=0;
#define true 1
#define false 0
void main()
	//TRISC = 0b10000000; no need to set TRISC as its the lowest priority if we've already set the TXEN, etc
	OSCCON= 0x75; //8Mhz High Freq Clock, can be fine tuned using OSCTUNE
	TRISE = 0x08;
	TRISB = 0xF0;
	ADCON1 = 0x07;
	init_rs232();
	static bit m_Switched = false;
	while(1){
//Global or main function variable.
if((!RE3) && (!m_Switched))
{	m_Switched = true;
/*   ???	//m_Count=0
	m_Count++;
	switch(m_Count){
	case 1:
		RB0 = 1;
		printf("/// \r\n\0");		// AT mode
		break;
	case 2:
		RB1=1;
		printf("AT*AGND \r\n\0");	// search fr new device
		break;
	case 3:
		RB0=1;
		RB1=1;
		break;		}
		if (RB0==0)				{
	 	RB0 = 1;
		printf("/// \r\n\0"); 	}	//goes into AT mode
}  else if((RE3) && (m_Switched))
{	m_Switched = false;
	RB0 = 0;
			/*		//int click=0;
					switch(!RE3){
						case1:
							PORTB=0b00000001;
void init_rs232()
	BRGH = 1;	// high baud rate to avoid baud rate error & bcos 16bit achieve slow baud rates fr fast osc freq
	BRG16 = 0;
	SPBRG = 8;		// Fosc=8Mhz, ,16, BR=57600
	TX9  = 0;	// 9bits=1: 8-bit=0
	SYNC = 0;	// asynchronous
	SPEN = 1;	// enable serial port pins
	TXEN = 1;	// enable the transmitter & (automatically)TXIF=1
	CREN = 1;	// enable reception
	SREN = 0;	// no effect
	TXIE = 0;	// disable tx interrupts
	RCIE = 0;	// disable rx interrupts
	RX9  = 0;	// ninebits?1:0,,,8- or 9-bit reception
void putch(unsigned char byte)
{	/* output one byte */
	while(!TXIF)	/* set when register is empty */
		continue;
	TXREG = byte;
unsigned char getch()
{	/* retrieve one byte */
	while(!RCIF)	/* set when register is not empty */
		continue;
	return RCREG;
unsigned char getche(void)
{	/*echo @ HT*/
	unsigned char c;
	putch(c = getch());
	return c;
the above codes cant seem to be working (i'm not sure if its receiving anything but there's no echo seen in the HT) =// did i insert the codes at the correct place?
Erm,
I dont see you calling getche anywhere in your code, unless I have missed anything, it is 2.30 am here.
You initialise the variable when you define it, so change int m_Count;
to:
int m_Count = 0;
There is a lot of unused code, which can make it difficult to read sometimes, it looks as if you have a } in the wrong place, but without formatting the code it isn't easy to be sure.
Do you get any compiler errors or warnings such as "code unreachable" ?
Wilksey
ohhhh its 10.58am here now. such a big time difference there.
oh! cos i saw ur codes as "unsigned char", thus am not sure if i'm in a dilemma of how to call them..
lemme try in inserting
 void getche(unsigned char c)
Nope there isnt any errors shown upon compilation. guess its clearer to see it here as it can be easily differentiated between the unused and the used codes =/
argh...oh man...am slightly confused now..hmm about the switch case..
its now
	m_Count++;
	switch(m_Count){
	case 1:
		RB0 = 1;
		break;
	case 2:
		RB1=1;
		break;
	case 3:
		RB0=1;
		RB1=1;
		break;		}
in the void main() but still no results
lemme tidy up my codes and i show u the final one i am having right now
	#include<pic.h>
	#include<htc.h>
	#include<conio.h>
	#include<stdio.h>
#define MHZ *1000L
continue; }
void init_rs232();
//void getche (unsigned char c);
int m_Count=0;
#define true 1
#define false 0
void main()
	OSCCON= 0x75; //8Mhz High Freq Clock, fine tuned using OSCTUNE
	TRISE = 0x08;
	TRISB = 0xF0;
	ADCON1 = 0x07;
	init_rs232();
	while(1){
getch();
getche();
/*	m_Count++;
	switch(m_Count){
	case 1:
		RB0 = 1;
		break;
	case 2:
		RB1=1;
		break;
	case 3:
		RB0=1;
		RB1=1;
		break;		}
		if (!RB0)				{
	 	RB0 = 1;
		printf("/// \r\n\0"); 	}	//  should go into AT mode
	RB0 = 0;
void init_rs232()
	BRG16 = 0;
		continue;
	TXREG = byte;
		continue;
	return RCREG;
{	/*echo @ HT*/
	unsigned char c;
	putch(c = getch());
	return c;
You are calling getch and getche, you can only call one, also, you are not storing the return value.
So, by calling getch you are clearing the buffer, but not putting it anywhere, thus clearing the buffer, so when you call getche the buffer is cleared previously by getch.
Try removing getch(); from your code and leave getche(); in place.
You can do a simple test by using this:
while(1)
    getche();
This should eliminate any hardware / switch issues.
Wilksey
Ohhh...sort of understanding it..
hmm i followed ur advice and tried
void main()
	TRISE = 0x08;
	TRISB = 0xF0;
	ADCON1 = 0x07;
	init_rs232();
while(1){
getche();
/*	m_Count++;
	switch(m_Count){
	case 1:
		RB0 = 1;
		break;
	case 2:
		RB1=1;
		break;
	case 3:
		RB0=1;
		RB1=1;
		break;		}
		if (!RB0)		{
	 	RB0 = 1;
	RB0 = 0;
but still to no avail =(( and the switch still doesnt work too =/
and even when i use back the if else instead of the swtich case as shown above, the led and switch doesnt work too (is it due to the getche() ?
I guess I should have said you need to post something to the module to get a response such as "OK", can you issue a standard ATI command and get information back from the module?
Calling getche on its own will just wait for a never ending response, unless it data is comming through regardless?
For ex:
while(1)
    printf("ATI\r\n");
    getche();
Wilksey
Hmm so i need to type in an AT command first prior to getting any echo?
hmm but my supervisor mentioned that we're (should be) able to somehow get a double "aa" or something when we, for eg, type "a" on te keyboard, sending it to the pic through HT.
Hmm will try it when i reach office in 3hr
Well,
If connecting to HT then it should echo back anything typed, so if you type "a" in hyperterminal, "a" should appear, unless you have "echo typed characters locally" enabled on HT, in which case you will get "aa" on the HT screen.
I thought you were interfacing with the BT module, not HT.
In which case, you cam take out the printf statement in my prev post.
I'll see if I can simulate the code here.
Wilksey
Ok, I have just simulated the code, and it works as it should.
If this doesn't work, I would suggest checking your 23
If this doesn't work, I would suggest checking your 232 connection, one thing you could do is download an application called Moxa Data Scope, or terraterm, and see the raw hex data comming through the port, you should be able to tell if there is anything funny happening.
Anyway, here is the code that works for me:
	#include<pic.h>
	#include<htc.h>
	#include<conio.h>
	#include<stdio.h>
	__CONFIG(WDTDIS & INTIO & MCLRDIS);
void init_rs232();
#define true 1
#define false 0
void main()
	OSCCON = 0x75;
	TRISA0 = 1;
	TRISB = 0x00;
	init_rs232();
	static bit m_Switched = false;  //Global or main function variable.
		while(1)
			getche();
		/*	if (RA0) //&& (!m_Switched))
				m_Switched = true;
				RB0 = 1;
				printf("Apple\r\n");
			else if(!RA0)
				m_Switched = false;
void init_rs232()
	BRGH = 1;
	BRG16 = 0;
	SPBRG = 51;	/* set baud rate: Fosc=8Mhz, 16, BR=9600 */
	TX9  = 0;	/* ninebits?1:0,,,8- or 9-bit transmission */
	SYNC = 0;	/* asynchronous */
	SPEN = 1;	/* enable serial port pins */
	TXEN = 1;	/* enable the transmitter & (automatically)TXIF=1 */
	CREN = 1;	/* enable reception */
	SREN = 0;	/* no effect */
	TXIE = 0;	/* disable tx interrupts */
	RCIE = 0;	/* disable rx interrupts */
		continue;
	TXREG = byte;
unsigned char getch() {
		continue;
	return RCREG;
	unsigned char c;
	putch(c = getch());
	return c;
Wilksey
Oh so
while(1)
    printf("ATI\r\n");
    getche();
is the way to do it when BT is connected eh?
Hmm cos i was thinking to do it step by step from getting a result out of HT itself before trying to get the BT out. yup for the past 2 days, i've been trying that similiar code of writing in only the "getche();"
the 232 should still be working as i used back the "/// output" experiment to ensure that all foundations are still working well.
and yes, i've checked "echo typed characters locally" enabled but one 1 "a" appear. [this echo thing's making me confused about the simple HT now =/]
urgh, i really hope i can, at least, get the echo out today. afterwhich, i would want to try out that "OK" is shown when i type AT in HT. then i can go back to the switch problem =/ i'll try to use ur codes to countercheck with mine too.
codings driving me crazy.
Did you check the input to the PIC as well as the output?
It's the input that is mainly effected by the level shifting i.e. RX pin.
If you have turned on "echo" but have only 1 'a' displayed, and printf etc works fine (test, before the while(1) loop add a "printf("Testing RS232\r\r");"), then there is something iffy with your transmit to PIC receive circuitry.
Hyperterminal itself is simple, it's a "dumb terminal".
Unless there is something majorly wrong with your code, then it isn't a coding issue.
It will be more likely a timing / hardware issue, which is why I suggest using Terraterm Pro or Moxa Datascope utility instead of Hyperterminal, or something that can display the HEX representation of what is comming out of the MAX232 circuitry.
At this stage, it's all about debugging!
One thing you could do, is connect RX to TX on the 232 circuit (TTL side), temporarily. bypass the PIC, and check that the characters are echoed back through hardware.
Can you isolate power to the pic from the 232 converter? Might be a useful exercise.
With the HEX representation idea, you send a uppercase A for example which is ASCII 65, HEX 41, you should see RXing a code 41, if you see something like FE, FF, 00, C1 etc, that means there is data corruption, and the levels are not shifting correctly.
If you see nothing at all, there is a major issue with either the PIC or the 232, in which case, conduct the loopback test (TX to RX on TTL side of the 232 circuit), eliminate the issues / potential issues 1 by 1!
Good luck, i'm sure you will be able to find the problem.
Wilksey
