    Dismiss Notice
PIC16F676 voltmeter Pinout
Discussion in 'Microcontrollers' started by manoj soorya, Aug 12, 2017.
  1. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Hi all...
    I have a Voltmeter with PIC16F676...with source code too... its working good. I need to change the PINOUT of the IC to the display. This is a part of the original code.
    Code (text):
    void io_init()
       {TRISA = 0b00001001;          // Ïîðò RA0  - âõîä
        PORTA = 0b00000100;
        TRISC = 0b00000000;
        PORTC = 0b00001010;
        ADCON0 = 0b00000001;  // Êîíôèãóðèðóåì AN0 êàê àíàëîãîâûé
        ADCON1 = 0b10000101;  // 1110 D D D D D D D A VDD VSS 1/0
        CMCON = 7;}           // Âûêëþ÷àåì êîìïàðàòîð
    void Dig_init()
       {Dig[0]  = 255-(a+b+c+d+e+f);   // Åñëè èíäèêàòîð ñ îáùèì àíîäîì,
        Dig[1]  = 255-(b+c);           // íóæíî ñóììó ìàêðîñîâ îòíÿòü îò
        Dig[2]  = 255-(a+b+g+e+d);     // 255. Åñëè ñ îáùèì êàòîäîì, òî
        Dig[3]  = 255-(a+b+g+c+d);     // îòíèìàòü íå íóæíî.
        Dig[4]  = 255-(f+g+b+c);       // Èìåíà ìàêðîñîâ ñîîòâåòñòâóþò
        Dig[5]  = 255-(a+f+g+c+d);     // èìåíàì ñåãìåíòîâ èíäèêàòîðà
        Dig[6]  = 255-(a+f+g+c+d+e);   // Ïðèìåð:
        Dig[7]  = 255-(a+b+c);         // Dig[7]  = 255-(a+b+c);
        Dig[8]  = 255-(a+b+c+d+e+f+g);
        Dig[9]  = 255-(a+b+c+d+f+g);
        Dig[10] = 255-0;}
    void Display() { // Âûâîä íà äèñïëåé
        RA = 0b00000000;    // Èíäèêàòîðû ïîãàøåíû  ðåæèì ÎÀ RA2, RC1, RC3 = 0
        RC = 0b00000000;    // Âñå ñòîëáöû K ðàâíû 1 Âñå ñåãìåíòû (a - h) ðàâíû 0
        delay_Cyc(2);
        if (ColCount >= 3) ColCount = 0; // åñëè ñ÷åò÷èê ñòîëáöîâ >= 3 îáíóëÿåì åãî
        switch (ColCount) {
            case 0 : RA.f2 = 1; break; // Âûáîð èíäèêàòîðà K1
            case 1 : RC.f1 = 1; break; // Âûáîð èíäèêàòîðà K2
            case 2 : RC.f3 = 1; }      // Âûáîð èíäèêàòîðà K3
        RC.f0 = Segment[ColCount].f0;  //a
        RC.f2 = Segment[ColCount].f1;  //b
        RA.f4 = Segment[ColCount].f2;  //c
        RA.f1 = Segment[ColCount].f3;  //d
        RA.f5 = Segment[ColCount].f4;  //e
        RC.f4 = Segment[ColCount].f5;  //f
        RC.f5 = Segment[ColCount].f6;  //g
        PORTA = RA; PORTC = RC;
        ColCount++; }
    and I changed this like...
    Code (text):
    switch (ColCount) {
            case 0 : RA.f4 = 1; break; // Âûáîð èíäèêàòîðà K1
            case 1 : RA.f1 = 1; break; // Âûáîð èíäèêàòîðà K2
            case 2 : RA.f5 = 1; }      // Âûáîð èíäèêàòîðà K3
        RC.f2 = Segment[ColCount].f0;  //a
        RC.f3 = Segment[ColCount].f1;  //b
        RC.f4 = Segment[ColCount].f2;  //c
        RC.f5 = Segment[ColCount].f3;  //d
        RA.f4 = Segment[ColCount].f4;  //e
        RC.f1 = Segment[ColCount].f5;  //f
        RC.f0 = Segment[ColCount].f6;  //g
    compilation is okey.. but the second code doesnot work ....... any help would be appriciated...
    Thank you
  2. sagor1
    sagor1 Member
    Dec 11, 2014
    52
    2
    You are setting RA.f4 twice, once in the case select, and then possibly in the part where you set "segment"
  3. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Thanks for remind me about RA.f4...
    This is the complete code...
    Code (text):
    /* Îïèñàíèå: Âîëüòìåòð äëÿ èçìåðåíèÿ íàïðÿæåíèÿ
       ñåòè ïåðåìåííîãî òîêà íà 3õ7ñåã èíäèêàòîðå
     * Êîíôèãóðàöèÿ: PIC16F676, Âíóòðåííèé, 4 MHz
       mikroC PRO for PIC  */
    // Ïîäêëþ÷åíèå ñåìèñåãìåíòíûõ èíäèêàòîðîâ.
    #define a 1   // Ýòè ìàêðîñû ñîäåðæàò ÷èñëà, ñîîòâåòñòâóþùèå äâîéêå,
    #define b 2   // âîçâåäåííîé â ñòåïåíü, ðàâíîé íîìåðó "íîæêè" òîãî
    #define c 4   // ïîðòà, ê êîòîðîìó ïîäêëþ÷åí ñåãìåíò èíäèêàòîðà ñ
    #define d 8   // îäíîèìåííûì ìàêðîñó íàçâàíèåì. Äëÿ òîãî, ÷òîáû âûâåñòè
    #define e 16  // êàêóþ-ëèáî öèôðó íà èíäèêàòîð, íóæíî îòïðàâèòü â ïîðò
    #define f 32  // ÷èñëî 255 ìèíóñ ñóììó ñîîòâåòñòâóþùèõ ñåãìåíòàì ìàêðîñîâ.
    #define g 64  // Ýòè ÷èñëà ïîçâîëÿþò ñäåëàòü ïðîãðàììó íåçàâèñèìîé îò ïîäêëþ÷åíèÿ.
    #define DP 128// Èçìåíèòå ýòè ÷èñëà, åñëè èíäèêàòîð âûâîäèò áóêâó "çþ"
    unsigned int i = 1; // ïåðåìåííàÿ ñ÷åò÷èêà
    unsigned char Dig[11]; // Ìàññèâ, â êîòîðîì õðàíÿòñÿ ÷èñëà, êîòîðûå íóæíî
    // âûâåñòè ÷åðåç ïîðò íà èíäèêàòîð, ÷òîáû îí ïîêàçàë öèôðó, ðàâíóþ íîìåðó
    // ýëåìåíòà ìàññèâà. ×èñëà çàâèñÿò òîëüêî îò ìàêðîñîâ.
    static char Segment[3] = {0x7f,0x7f,0x7f};
    static unsigned char ColCount = 0; // Ñ÷åò÷èê íîìåðà èíäèêàòîðà
    unsigned result, resmax, resmin;           // Ðåçóëüòàò èçèåðåíèÿ
    unsigned char RA, RC; // Ïðåäâàðèòåëüíûå çíà÷åíèÿ PORTA è PORTC
    void io_init()
        PORTA = 0b00000100;
        TRISC = 0b00000000;
        PORTC = 0b00001010;
    void Dig_init()
        Dig[10] = 255-0;}
        delay_Cyc(2);
        switch (ColCount) {
        RC.f0 = Segment[ColCount].f6;  //g               manoj
        ColCount++; }
    void HTO7S(unsigned long int Num)  {  // Ïðåîáðàçîâàíèå â 7-è ñåãìåíòíûé êîä
        Segment[0] = Dig[Num / 100];
        if (Segment[0] == Dig[0]) Segment[0] = Dig[10];
        Segment[1] = Dig[Num % 100 / 10];
        if ((Segment[1] == Dig[0]) && (Segment[0] == Dig[10])) Segment[1] = Dig[10];
        Segment[2] = Dig[Num % 10];}
    void Init_Timer1 () { //Èñïîëüçóåòñÿ ìîäóëü Timer1
        INTCON.GIE = 1;
        INTCON.PEIE = 1;
        T1CON = 0x01;
        TMR1H = 0x00;
        TMR1L = 0x00;
        // T1CON.T1CKPS0 = 1;  // Äåëèòåëü íà 2    Äëÿ Proteus
        // T1CON.T1CKPS1 = 1;  // Äåëèòåëü íà 4    Äëÿ Proteus
        PIE1.TMR1IE = 1;}    // Ðàçðåøåíèå ïðåðûâàíèÿ ïî ïåðåïîëíåíèþ TMR1
    void interrupt () {
        if (PIR1.TMR1IF)    // Îáðàáîò÷èê ïðåðûâàíèÿ ïðè ïåðåïîëíåíèè TMR1
            {TMR1H = 0xF7;   // Ïåðèîä 6,2 ìñåê
            PIR1.TMR1IF = 0;
            Display();}}
    void main() {   // Ïðÿìîå èçìåðåíèå ïåðåìåííîãî íàïðÿæåíèÿ
        io_init();
        Dig_init();
        Init_Timer1();
        do {result=0;
            resmax=0;
            resmin=65535;
            for (i=0;i<200;i++) {
                delay_us(1);
                result=Adc_Read(0);
                if (result > resmax) resmax=result;
                if (result < resmin) resmin=result; }
            result=resmax-resmin;
            HTO7S(result / 4); // Äî 255 âîëüò
            delay_ms(500);}
        while (1);  // Áåñêîíå÷íûé öèêë
    [CODE END]
    Regarding
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. sagor1
    sagor1 Member
    Dec 11, 2014
    52
    2
    Re-check the initial settings (values) for PortA and PortC. The program initially set PortA = 00000100 and PortC to 00001010. Since you are changing pin definitions, do you not have to change the initial values as well? Just a thought....
    I'm not good with C at all, so that is about as far as I can go...
  6. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Thanks sagor1. will try with the initial values......
    Thank you so much for your reply....
  7. Superdat
    Superdat Member
    Mar 3, 2015
    104
    3
    ONLINE
    You might get a better response if this was posted in a "C" forum, this is Oshonsoft Basic.
    I know some Oshonsoft contributers understand C, but as I said a "C" forum might get a better level of help.
    I'm just strating to learn C so I'm afraid I'm of no help
  8. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Ok and Thanks Superdat....
  9. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,038
    892
    Rochdale UK
    Moved to the correct forum!!
  10. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Many Thanks Admin....
    I think I already post in the C forum..... :nailbiting:
  11. Ian Rogers
    Mar 28, 2011
    9,038
    892
    Rochdale UK
    No! You posted in the depository... This is for code that has been written to help others... I deleted it..
    • Like Like x 1
  12. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    how can I access my thread in the new forum, Admin?
  13. Ian Rogers
    Mar 28, 2011
    9,038
    892
    Rochdale UK
    You just did..
    • Like Like x 1
  14. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Hello Admin..
    may I hope your help regarding my post?
  15. Ian Rogers
    Mar 28, 2011
    9,038
    892
    Rochdale UK
    Sagor has already replied with the answer!! Change the TRIS registers to suit!!
    • Like Like x 1
  16. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    I try much time with datasheet and pinout of 16F676... I do not dunderstand what is " TRSIA, ADCON and CMCON in my code.. and how to set corresponding to my needs.... really tired... But whenever I change in source, the display will change.. :)
    Thank you so much Ian Roger
  17. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Tell me one thing Ian Rogers
    Is the only need to set the TRISA?
    Thank you so much for your replay..
  18. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    I am trying again... Thank you Admin...
    Regards Manoj
  19. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    Is this correct Ian Rogers?
  20. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
  21. manoj soorya
    manoj soorya Member
    Aug 23, 2014
    238
    4
    India
    ohhhh..... its not a simple task to mine....:banghead:
Share This Page
