PIC12F675 Software PWM - LED Driver
wuchy143
Hi All,
I see that there are not many PWM examples in regards to software PWM on Microchips PIC12F675. Or at least useful examples were not easily found when I googled it and since I took the time to write my own maybe someone could use it.
Please be warned. In my design the PIC12F675's ONLY job is to do PWM and that's it. If you need to do other useful things like be a UART...or anything that takes time...then this code will probably be useless to you.
Operation:
I attached the schematic. Essentially I read two port pins(GP5 and 3) to determine the LED brightness. So GP3 goes low the LED intensity goes up. GP5 goes low the LED intensity goes low.
After ~5 seconds of the user not changing the brightness the PIC saves the value in E^2 so it can remember the brightness level if power is lost.
I did put a small bit of hysteresis on the switches.
Any questions/comments good or bad please let me know.
Enjoy.
-mike
 void PWM(void);
 void Read_Buttons(void);
  const unsigned int PWM_Inputs[200] =
  { 200, 199, 199, 199, 199, 199, 198, 198, 198, 198, 198, 197, 197, 197,
    197, 197, 196, 196, 196, 196, 196, 195, 195, 195, 195, 195, 194, 194,
    194, 194, 194, 193, 193, 193, 193, 193, 192, 192, 192, 192, 192, 191,
    191, 191, 191, 191, 190, 190, 190, 190, 190, 189, 189, 189, 189, 189,
    188, 188, 188, 188, 188, 187, 187, 187, 187, 187, 186, 186, 186, 186,
    186, 185, 185, 185, 185, 185, 184, 184, 184, 184, 184, 183, 183, 183,
    183, 183, 182, 182, 182, 182, 182, 181, 181, 181, 181, 181, 180, 180,
    180, 175, 175, 175, 170, 170, 170, 165, 165, 165, 160, 160, 160, 160,
    155, 155, 155, 150, 150, 150, 145, 145, 145, 140, 140, 140, 135, 135,
    135, 130, 130, 130, 125, 125, 125, 120, 120, 120, 115, 115, 115, 100,
    100, 100,  95,  95,  95,  90,  90,  90,  80,  80,  80,  70,  70,  70,
     70,  70,  60,  60,  60,  60,  60,  50,  50,  50,  50,  50,  40,  40,
     40,  40,  40,  30,  30,  30,  30,  30,  20,  20,  20,  20,  20,  15,
     15,  15,  15,  15,  10,  10,  10,  10,  10,   5,   5,   5,   5,   1,
     1,   1,   1,   1};
 //--------------------------   VARIABLE INITIALIZATION   --------------------//
 unsigned int Time = 0x00;
 unsigned int Duty_Cycle = 0x00;
 unsigned int Duty_Cycle_Mirror = 0x00;
 unsigned int i = 0x00;
 unsigned int debounce = 0x00;
void main()
CMCON    = 0x00;                // Disable comparators
ANSEL    = 0b00000000;          //assigning digital i/o all ports
TRISIO   = 0b00101000;          //setting ports GP3(pin4) / GP5(pin2) to inputs
//fetch previous backlight intensity before powerdown
Duty_Cycle = EEPROM_Read(0);
if(Duty_Cycle > 200)
    Duty_Cycle = 0;
    Duty_Cycle_Mirror = 0;
else
Duty_Cycle_Mirror = Duty_Cycle;
//-----------------------------   MAIN LOOP   --------------------------------//
while(1)
       PWM();
       Read_Buttons();
       i++;
       if(i >= 385 && (Duty_Cycle != Duty_Cycle_Mirror))
               i = 0;
               GP4_bit ^= 1;
               EEPROM_Write(0, Duty_Cycle_Mirror);
       Read_Buttons();
void PWM(void)
{        Time = 0;
         while(Time <= 200)
               if(Time > PWM_Inputs[Duty_Cycle])
               Time++;
               GP2_bit = 0;
               else
               GP2_bit = 1;
               Time++;
   if(GP3_bit == 0)
        i = 0;
        debounce++;
        if((Duty_Cycle < 199) && (debounce >= 2))
        debounce = 0;
        Duty_Cycle++;
   if(GP5_bit == 0)
        i = 0;
        debounce++;
        if((Duty_Cycle > 0) && (debounce >= 2))
        debounce = 0;
        Duty_Cycle--;
Questions:
1) What's D130 for, faster off-fall vs slower-on rise time?
2) 1K limits LED current to 3mA with a 2 Vf LED drop, that's a bit low for full brightness.
3) A Pfet is usually more expensive & less efficient @ switching than an NFET given Rds On and rise time.
4) Why not use the Weak pull ups rather than external 10K resistors.
5) 0 Ohm resistors in a schematic? One pulling an i/o to ground with a 10K going to Vdd and the other shorting the switching FET Drain to Source.
edit:I fear K8LH is confusing me with someone else.
Mike (wuchy143),
Thank you for posting. Would you mind mentioning which C compiler you're using for those members who might like to duplicate your example?
Cheerful regards, Mike
