    Dismiss Notice
pic compiling/programming questions
Discussion in 'Microcontrollers' started by breadboardguy, May 7, 2009.
  1. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,801
    134
    morristown,tn
  2. breadboardguy
    breadboardguy New Member
    Apr 27, 2009
    140
    0
    montreal, Canada
    ...you really think i am that newb?
    (and i dont get what you mean, i know what is a tsop31256 and a tsal6200)
    To Nigel:
    Doesnt works without the 330 ohms resistor.
  3. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,216
    640
    Derbyshire, UK
    As suggested above, check my tutorial which shows how to connect a TSOP, you're missing vital decoupling components, and like I said, 330 ohms is FAR too low, if any resistor is needed at all. Try a 10K or 47K as pullup, but add the rest of the components as my tutorial - notice mine uses a 10K, but will work without it.
    Nigel's PIC Tutorial Infrared Board
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. be80be
    Aug 23, 2008
    4,801
    134
    morristown,tn
    No but I sure no how old you are. You can build it any way you want when it brake's
    You fix it. When it gos up in smoke you buy it back.
  6. npolynomial
    npolynomial New Member
    Jun 14, 2009
    4
    0
    PIC16F84A is unjustifiably expensive, but it will work for you, it is the flash version (upgraded) of the 16c84...
    MPLAB can take your asm program and convert it to the pic16f84a's machine language. Make sure you select which device you are trying to develop for, it is important so that it can assign the correct registers.
    asm programming is in my opinion slightly easier and far more versatile than basic, so good choice. However, for very advanced design you will almost certainly need to use C.. I'm working on a C++ compiler for PIC Micros... I'll be excited when I'm completed!
    You can use so many different ways of actually loading the hex into the PIC. I recommend buying a USB one from melabs they are cheap and can program almost all of the PICs in existance. Alternatively, microchip has some on their website, and there are also industrial tpyes that can program in 1 second to 16 chips at a time...costing about 800 dollars. Well worth it in the long run if you mass produce your designs.
    Sincerely,
    Jesse Randall
    Electronic Engineer
    Complete Turn-key Digital Electronics Design Nova Conceptions - Home
  7. Nigel Goodwin
    Nov 17, 2003
    39,216
    640
    Derbyshire, UK
    Certainly no one should be using an 16F84, and shouldn't have been for a decade or so - but, it's NOT a FLASH chip.
    The 16F84 was the replacement for the 16C84, mainly curing a bug in the code protection routines, where the 16C84 was relatively easy to break the protection on.
    Both use the same EEPROM memory techology, as do the vast majority of the F series - only some of the very latest ones are actually FLASH.
  8. skyhawk
    skyhawk New Member
    Feb 9, 2007
    235
    7
    Morgantown, WV
    You obviously have not been following this thread. The OP is a young hobbyist with limited financial resources. He has already bought a PICkit 2 and 16F628As and 18F2525s.
  9. breadboardguy
    Apr 27, 2009
    140
    0
    montreal, Canada
    That is really strange, only the port b works as input on all my 16f628a. Do i have to set to port in some way?
    This problem driven me crazy because i was wondering why my 3 line program was not working.Works on port b...
    Works here
    doesnt here...
  10. be80be
    Aug 23, 2008
    4,801
    134
    morristown,tn
    How would one no what is wrong can't see your code from here. Here why
    Code (text):
    Start:
    [COLOR="Red"]   movlw   0x07
        movwf   CMCON   ;turn comparators off[/COLOR]
        movlw B'00000000  ;loads w
        banksel TRISA     ;moves to tris reg.
        movwf TRISA    ;wirtes to tris setting all to out put
        banksel PORTA  ; moves to Porta reg
        clrf PORTA     ; sets all pins to output
    most likely the part in red
  11. skyhawk
    skyhawk New Member
    Feb 9, 2007
    235
    7
    Morgantown, WV
    You have to turn off the comparators on port A.
  12. skyhawk
    skyhawk New Member
    Feb 9, 2007
    235
    7
    Morgantown, WV
    PICs reset with analog inputs enabled. Use to disable comparators.
    Code (text):
    movlw   0x07
    movwf   CMCON
  13. breadboardguy
    Apr 27, 2009
    140
    0
    montreal, Canada
    Thanks for the info.
Share This Page
