    Dismiss Notice
philips red driver problem
Discussion in 'Repairing Electronics' started by aranger, Dec 8, 2008.
  1. aranger
    aranger New Member
    Dec 8, 2008
    5
    0
    I have a Philips model # 30pw8869/17 HDTV that has a red tint and retrace lines. When the channel is changed or it is powered on it goes completely red for a moment. I plan on changing all the bad electrolytic Caps and trying to narrow down the red driver circuit. Does anyone happen to have the schematics for this model or has run into this problem before. I am no expert with TV repair so any help and information would be greatly appreciated.
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    Most common cause on Philips is CRT failure - assuming it's a CRT TV of course.
  3. aranger
    aranger New Member
    Dec 8, 2008
    5
    0
    Yes it is a CRT, Is there an easy way to tell if it is or isn’t the CRT? When the picture is bright as in the show being played, the picture looks good its only when it is a dark program or the channel is changed that the red shows up.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Nigel Goodwin
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    Swap the red and one of the other colours over, actually on the pins on the CRT - there's usually a series resistor feeding directly to the pins, remove one end of the red resistor, and one end of one of the others, and cross connect them.
    If the fault is still on the red, then it's the CRT at fault - but Philips have had MASSIVE CRT failure problems, it's really been a complete disaster over the last few years of CRT's.
  6. aranger
    aranger New Member
    Dec 8, 2008
    5
    0
    Ok I swapped the green resistor with red there is a slight green tint now. When I change the channel or first turn it on it still does the red for a moment thing. Is this a bad CRT?
  7. Nigel Goodwin
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    Yes, as expected with a Philips.
  8. aranger
    aranger New Member
    Dec 8, 2008
    5
    0
    Thanks for your help at least now I know I’m assuming the CRT will be way too expensive to replace.
  9. Nigel Goodwin
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    Assuming you could even source one (they were rare because they mostly all failed), it would probably cost more than a new set.
    Far cheaper to buy another CRT set, as they are pretty well worthless these days - we give away or throw away loads of good working 28 and 32 inch CRT's.
  10. aranger
    aranger New Member
    Dec 8, 2008
    5
    0
    Wish you were located in AZ so I could pick up one of those thro ways, but thanks guess I’ll have to live with it until I can afford another set. I thought it was in the board so thanks again you saved me a lot of time and money I would have spent trying to fix it.
Share This Page
