OEG SDT-S-109LMR what is it doing?
Datenshi
Hi, im tinkering with an old subwoofer that came with a dvdset(Akai DV-3400SS), what i want to do is remove the amplifier and use it for another subwoofer, the problem is i believe it requires a b+ 10v power from a dvd to power on.
The small PCB that receives the 230v power cord has an OEG SDT-S-109LMR component on it(Power PCB Relay) which i suspect triggers on/off depending on whether that 10v line is present. I need someone to tell me if im right and if its possible to bypass this component to allow me to have it ON as soon as i plug in the powercord in the wall(without the dvd present)
I can't take pictures of the PCB's atm but if the need is there i can get some. Thanks
Here's a PDF i found on tyco electronics website.
https://www.tycoelectronics.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Customer+Drawing%7F7-1419125-9%7FC%7Fpdf%7FEnglish%7FENG_CD_7-1419125-9_C.pdf
